Pros and Cons of current feedback amplifier. - Page 11 - diyAudio
Old 18th March 2013, 11:19 PM   #101
Banned
Originally Posted by Bonsai View Post
But VFA bandwidth and rise time is inferior to CFA.
No.
Old 18th March 2013, 11:23 PM   #102
Lazy Cat's Avatar
Originally Posted by michaelkiwanuka View Post
To reiterate:
1) There is no need for excessive bandwith in audio applications.
2) "CFAs" deliver significantly poorer linearity than VFAs.
3) "CFAs" deliver poorer PSRR than well designed VFAs.
4) There is no need for servos with well designed VFAs; this not true of "CFAs".
There is no conceivable excuse for using "CFAs" in audio applications.
Completely wrong!
Old 18th March 2013, 11:32 PM   #103
Banned
Old 18th March 2013, 11:49 PM   #104
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
No.
Yes. You can only achieve higher SR and BW by going for MIC, or if non MC, some suboptimal comp scheme. And, whatever scheme you choose, VFA's always require more circuit complexity.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 18th March 2013, 11:55 PM   #105
Banned
Just why would you want more bandwidth or slew than you need?
And what on earth is MIC?
It is relatively easy to design a VFA with 100V/uS slew rate using two pole compensation.
Old 19th March 2013, 12:00 AM   #106
Banned
....VFA's always require more circuit complexity.
No.
Old 19th March 2013, 12:01 AM   #107
Bonsai's Avatar
There is no need for excessively low distortion in audio.
CFA's easily deliver distortion orders of magnitude below the threshold of hearing, and at least 2-4 orders of magnitude lower than speakers and analog source material (specifically vinyl)
CFA PSRR is below audibility threshold, and is in any event easily solved with simple supply rail filtering
I have no servos in my two current CFA designs as the DC performance is very good ( under 5mV offset). Both designs are fully DC coupled.
VFA's tend to be more complexed expensive than CFA's and yet offer no audible benefit
bonsai
Old 19th March 2013, 12:11 AM   #108
Banned
There is no such thing as "excessively low distortion".
Old 19th March 2013, 12:15 AM   #109
Telstar is offline Telstar  Italy
Originally Posted by Lazy Cat View Post
Completely wrong!
Point 3 I think was correct (PSRR).
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 19th March 2013, 12:21 AM   #110
Firstly, there is no need for an excessively large closed loop bandwith (say, greater than 2Hz~200KHz) in audio applications.
I have to disagree with the above statement. An amp with 200khz at the canonical -3db does introduce phase shifts in the audio band and is therefore sub-optimal.
What are the pros and the cons of those 3 vas ? tessier Solid State 93 30th January 2017 01:53 PM
Constant Current Pros and Cons GregH2 Solid State 196 5th April 2011 11:46 PM
Cons / Pros Borat Tubes / Valves 34 1st September 2009 12:52 PM
2 way + active sub in same cabinet pros and cons? FE3T Multi-Way 6 12th September 2008 10:34 PM
Pros and Cons of this technique? G Tubes / Valves 35 23rd October 2003 05:37 PM
Copyright 1999-2017 diyAudio
