Repairing a Kenwood KA-7300
Old 20th September 2012, 04:01 PM   #11
ZAPBANG is offline ZAPBANG
Smile Removing the voume/balance knobs
Originally Posted by hpp3 View Post
Ah yes, I hadn't taken into account the age of the thing and started with caps first.
That would explain why it still passes sound, but very thinly.
I've also wanted to clean the pots and switches, as the input selector switch would sometimes drop the right channel, but have had no success getting the front panel off.
Do you have any advice for removing the central volume control?
It's the only knob that doesn't simply pull off.
Hi, yes, that knob was a bear for me also. I finally got it though. I was using an allen wrench that was too big. I slipped a VERY tiny bulb into one of the screw holes and peeked at the lit setscrew. It is very small. It takes a 1/16" allen wrench to do the job. I also found that it took two cleanings with Caig Fader Lube / MCL to quiet the pots. I used 100% Deoxit on all the switch contacs. It is working just fine now. I use JBL L100 speakers on my test bench. Quite often they will bottom out while testing an amp with high volume and substantial bass. This Kenwood REALLY was impressive. Same levels, no bottoming out. Good luck on yours!!
Old 8th August 2014, 12:42 PM   #12
avignacio is offline avignacio
help guys, i have a ka-7300 trio, i'm having problem trouble shooting it. theres a cracking/ popping noise at both channels, even the volume is zero. dc volts is entering the speakers, ive tried replacing some capqcitors but no effect. i also try isolating the input wire of the amplifiers but still its crqcking. any any idea guys?
Repairing a Kenwood KA-7300Hide this!Advertise here!
Kenwood KA-400 gecko Solid State 87 30th January 2009 08:43 AM
Help with Kenwood KA-94 lumstar Solid State 0 7th January 2009 01:31 AM
Kenwood Ka-770b dexter2003 Solid State 7 3rd July 2008 06:22 PM
Kenwood KA-5040R Briek Solid State 2 4th March 2007 09:54 AM
Kenwood KA-88 gurusan Solid State 7 17th August 2004 12:18 PM
Copyright ©1999-2017 diyAudio
