Star ground
Star ground
Old 15th October 2003, 03:28 AM   #11
Kilentra is offline Kilentra  United States
Send a message via AIM to Kilentra
I'm using Anthony's boards and there still is a little bit of hum. I have imperfect power supply wiring myself. The problem may not be specific to your PCB layout. I'd look at perhaps isolating the earth grounds with a diode bridge, or ensuring a good power star ground[?]
Old 15th October 2003, 05:29 PM   #12
traderbam is offline traderbam  Europe
traderbam's Avatar
Running fb from SPKR is good. But move R11 close to R10 - otherwise you have a long aerial on the base of your diff pair.
Where is your Zobel network? This is an HF load for the amp.
BAM
Old 16th October 2003, 07:11 PM   #13
naula is offline naula  Finland
naula's Avatar
BAM
I think I will move the SPK connector to center of the board, next to C12. This will shorten the feedback circuit.
There is no Zobel network in the Anthony's design.
- Antti
Old 16th October 2003, 07:43 PM   #14
traderbam's Avatar
Yes you could do that, but my point is that the length of the track off the base is critical not the length of the whole feedback path. In fact I'd say leave the spkr term as far away from the input stage as you can to minimize inductive feedback - the currents in the speaker wire will be very large, or rather the transconductance of the amp will be very high compared with the voltage gain.
IMO the circuit should have a zobel. Otherwise, what is providing damping for the output stage at high frequencies?
Star groundHide this!Advertise here!
star ground vs. ground plane Sebastiaan Chip Amps 93 13th February 2017 11:41 PM
Star ground help g(f(e)) Tubes / Valves 26 24th December 2007 10:08 PM
Will this amp need a star ground? ghetto Chip Amps 3 25th August 2007 05:25 PM
Ground star JORGETronic Tubes / Valves 1 2nd June 2007 02:50 AM
Ground planes instead of star ground svokke Chip Amps 3 22nd October 2003 01:01 AM
