Death of Zen 15 watt Power Amplifier - diyAudio
Old 4th March 2012, 09:33 AM   #1
shaan is offline shaan  India
shaan's Avatar
Default DOZ - Death Of Zen 15 Watt Power Amplifier
Hi all.
The existing threads on DOZ seem to be about complains targeted to people who are not related to this amplifier and/or hollow debates on the supiriority of one amp over another.
So here is a thread where we can concentrate solely on DOZ as a standalone amplifier which produces music comparable to the sound of the best DIY Class-A amplifiers available.
I built both Capacitor coupled and Direct coupled versions; both with their advantages and disadvantages. The cap coupled version has less demand on the PS filtering and is less complex, while the direct coupled version has more stable bias and subjectively cleaner sound with no capacitor in the output and the feedback path.
Cheers...
PS. No Flaming Please, Comment only if you are interested in DOZ in a positive way.
Old 4th March 2012, 11:21 AM   #2
godfrey is offline godfrey  South Africa
Hi Shaan
Nice work! Dare we ask for a peek at the underside (or should I say dare you show it? )
A couple oh questions - What is the empty chip socket for in the 2'nd pic, and why on earth is there a tapped hole in one of the fins of the heatsink on the left?
btw, I found the DoZ details here on Rod Elliott's site, but no mention of a direct coupled version. Could you provide a schematic or a link?
Thanks - Godfrey
Old 4th March 2012, 11:34 AM   #3
just another
wintermute's Avatar
Knowing Shaan, it will be just as neat as the topside Very nice as usual Shaan!
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 4th March 2012, 10:28 PM   #4
shaan's Avatar
Originally Posted by godfrey View Post
Hi Shaan
Sure, tomorrow I will. Thanks.
The chip socket is for TL072, the offset servo. The tapped hole was there when I snatched the heatsinks from an ATX SMPS.
Thanks - Godfrey
Sure, see the attachment.
The PeeCeeBee Thread
Old 5th March 2012, 12:54 AM   #5
kp93300 is offline kp93300  Malaysia
HI Shaan
What is the estimated output into 8 R with the balance circuit above ?
What is the difference in sound between this amp and JLH ?
Always admire you work .
thanks
kp93300
Old 5th March 2012, 05:13 AM   #6
shaan's Avatar
kp93300,
The circuit is not balanced. The left board is capacitor coupled single supply type and the right board is direct coupled dual supply type with offset servo, both stereo. The above schematic shows the direct coupled design.
I don't know what the power output of a blanced circuit will be, but I am sure it will have less overall distortion.
Old 5th March 2012, 08:14 AM   #7
shaan's Avatar
Tony.
Thanks tony.
Old 5th March 2012, 08:18 AM   #8
shaan's Avatar
Hi Shaan
Here it is.
Old 5th March 2012, 08:42 AM   #9
shaan's Avatar
Default For the interested.
This is the exact schematic I used in the direct coupled version, everything except the power transistors are on-board. The diode-bridge+zener+bjt regulator for the opamp was a first time for me and it works well with no bad effect on the turn on/turn off event; i.e. no thump/click/pop etc..
Old 5th March 2012, 09:43 AM   #10
shaan's Avatar
thanks
kp93300
Into 8ohm load, I found no difference between them when TIP3055 is used with DOZ and 2SC5200 used with JLH'69. When I revert the transistors an interesting thing happens. DOZ sounds too bright with 5200(HF oscillation?) and JLH sounds okay with 3055, although with less treble. JLH seems more forgiving to transistor varieties.
Still, I chose DOZ as my favorite as, when used with cheap 3MHz transistors, 1) it has perfect balance in bass, vocal, treble; I can listen all day without getting bored and 2) My 4ohm speakers sounds equally fantastic to 8ohm ones with DOZ, JLH didn't pass this test.
Thanks for the kind words.
Some problems with Death Of Zen bezobraznia Pass Labs 22 26th March 2011 12:51 AM
death of zen janey Pass Labs 29 16th September 2009 09:59 PM
Choosing speakers for Death of Zen starbase218 Multi-Way 12 30th January 2007 03:56 PM
Death Of Zen DoomPixie Solid State 2 22nd August 2006 11:21 PM
Death Of zen On 15V supply? DoomPixie Solid State 18 21st August 2006 10:47 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
