#71 |
My experience with Capacitive Multipliers has been disappointing.
I would recommend a decent CRCRC circuit rather than a C.M. The impedance of the C.M. is quite high and can affect the frequency response of the amplifier. |
#72 |
Pd = Pmax * [Tmax - Tc] / [Tmax - T25]
using Pmax = 120W Tmax = 150°C Tc = Ts + 15Cdegrees = 70+15 = 85°C The maximum power of the 3055 with a 70°C heatsink interface temperature is de-rated to ~ 120 ~ 65 / 125 = 62W. Running the hottest part of the heatsink @ ~70°C effectively reduces your 3055 to a 62W device. Then you must de-rate for second breakdown at all the higher Vce imposed on the 3055. Some 3055 have a Pmax of 90W @ Tc=25C. |
#73 | |
I built the simple cap-multiplier in ESP site. Installed a 1000uF AFTER the multiplier as suggested in the webpage. Result:- No hum, Excellent frequency response in DOZ, as if there is nothing but wires between the DOZ and the main PS caps. Currently I use a simple CRC which gives the same hum-reduction plus bias-monitoring plus low-impedance. However, the multiplier was equally good, it just used extra components.
SSA Important Post Links:- How SSA Works, Nico's SSA, Nico's Thoughts on SSA Sound, Alex's SSA Mono PCB, LC's Scope Traces, SSA BIGBT PCB, SSA High Power Low Zout PCB, PeeCeeBee, SSA Speed, Why Current Feedback, Why SSA Is Unique, 20 Reasons To Go For SSA Last edited by shaan; 6th April 2012 at 11:43 AM. |
#74 | |
SSA Important Post Links:- How SSA Works, Nico's SSA, Nico's Thoughts on SSA Sound, Alex's SSA Mono PCB, LC's Scope Traces, SSA BIGBT PCB, SSA High Power Low Zout PCB, PeeCeeBee, SSA Speed, Why Current Feedback, Why SSA Is Unique, 20 Reasons To Go For SSA |
#75 |
#76 | |
#77 | |
Please Post DOZ Things Only. Thank you.
#78 |
OK - not trying to thread hop here.
The PSU is a vitally important part of any Class A amplifier project. I'll leave it up to the builders to try what they may. |
#79 |
Thank you very much.
#80 |
Hi AndrewT
Thanks for your input.Your calculation is good but I am electronic illiterate. Can you advice what is the optimum operating temp for the TIP 3055? The solution is to use a bigger heatsink or fan ? Hi Shaan, How to adjust the gain of DOZ ? thanks kp93300 |
| Some problems with Death Of Zen | bezobraznia | Pass Labs | 22 | 25th March 2011 11:51 PM |
| death of zen | janey | Pass Labs | 29 | 16th September 2009 08:59 PM |
| Choosing speakers for Death of Zen | starbase218 | Multi-Way | 12 | 30th January 2007 02:56 PM |
| Death Of Zen | DoomPixie | Solid State | 2 | 22nd August 2006 10:21 PM |
| Death Of zen On 15V supply? | DoomPixie | Solid State | 18 | 21st August 2006 09:47 PM |
