#11 |
Mr Shaan
excellent job like always regards Nikos |
#12 | |
Hi Shaan
What is the gain of this circuit ? How do i adjust the gain ? thanks kp93300 Quote:
#13 |
#14 |
Hi Shaan
How to adjust VR1 and VR2? What to measure during adjustment? Can i parallel the TIP 3055 for more power? What is the maximum Vin ? Sorry for so many questions? You have build so many amps and by your recommendation, I think I will give it a try also. I am extremely happy with a JLH 69 using 2n 3055 and if this can beat it, i will be over the moon ! thanks kp93300 |
#15 | ||||||
Thanks nikos. Thank you. Quote:
I believe you are soon to be over the moon....
SSA Important Post Links:- How SSA Works, Nico's SSA, Nico's Thoughts on SSA Sound, Alex's SSA Mono PCB, LC's Scope Traces, SSA BIGBT PCB, SSA High Power Low Zout PCB, PeeCeeBee, SSA Speed, Why Current Feedback, Why SSA Is Unique, 20 Reasons To Go For SSA |
#16 |
Hi all I have built the class A doz,and can confirm that it has that JLH full,rounded class A sound. The bass seems punchier and dynamic. Here are some pcb/overlay traces if anyone is interested.Good luck
#17 |
I agree totally with Mr Robertson, it indeed has that "JLH" full rounded class-a sound, plus better bass and low impedance load management. Nice simple PCB layout there.
#18 |
That is amazing work Shaan, it must have taken a very long time to complete!! What do you use to hold the conductors in place while soldering, and how do you bend them like that??
#19 | |
#20 | |||
Planning/placing/soldering the parts and pins - 1 hour. Soldering the connector - 2 hours. Quote:
The conductors are just cut-off legs of the resistors and capacitors, 100 parts=200 conductors, so I don't have to buy wires for this task. I hold the conductor with the tweezer, dip one end in the flux, tin the end with the iron, solder it to a joint on the board, press the conductor towards the board and make it flat over the board, bend it with the tweezer to reach the joint to be interconnected, solder the other end, and the cycle repeats. Quote:
With the 5200s I noticed the treble to sound disturbingly bright. Also these damn-fast transistors need some kind of oscillation prevention mechanism to be installed, like a Zobel or a capacitor in parallel with the series feedback resistor or a dominant pole capacitor(bandlimiting- bad, bad idea). Even an unearthed heatsink may cause oscillation when superfast transistors are used. As prevention is better than cure, so I use TIP3055s and the author of this design says that DOZ works(sounds) just as fine with 3055s, I found it to be true. As this is a current feedback circuit making the transistors work close to their maximum speed, the transient response is usually excellent even with slow transistors like 2N3055s. I have some 2N5296 TO220 devices with 800KHz fT and tested them with DOZ; they sound the same, awesome.
SSA Important Post Links:- How SSA Works, Nico's SSA, Nico's Thoughts on SSA Sound, Alex's SSA Mono PCB, LC's Scope Traces, SSA BIGBT PCB, SSA High Power Low Zout PCB, PeeCeeBee, SSA Speed, Why Current Feedback, Why SSA Is Unique, 20 Reasons To Go For SSA Last edited by shaan; 7th March 2012 at 12:44 AM. |
| Some problems with Death Of Zen | bezobraznia | Pass Labs | 22 | 25th March 2011 11:51 PM |
| death of zen | janey | Pass Labs | 29 | 16th September 2009 08:59 PM |
| Choosing speakers for Death of Zen | starbase218 | Multi-Way | 12 | 30th January 2007 02:56 PM |
| Death Of Zen | DoomPixie | Solid State | 2 | 22nd August 2006 10:21 PM |
| Death Of zen On 15V supply? | DoomPixie | Solid State | 18 | 21st August 2006 09:47 PM |
