#101 | ||
Hi guys. Sorry, I was out for some time due to serious net connection failure. How've you been?
Steps:- 1K resistor from positive rail to zener negative lead. Zener positive lead goes to ground. Disconnect VR from positive rail and connect the pin to zener negative lead. Done. ![]() Cheers.
SSA Important Post Links:- How SSA Works, Nico's SSA, Nico's Thoughts on SSA Sound, Alex's SSA Mono PCB, LC's Scope Traces, SSA BIGBT PCB, SSA High Power Low Zout PCB, PeeCeeBee, SSA Speed, Why Current Feedback, Why SSA Is Unique, 20 Reasons To Go For SSA |
#102 |
Hi all,
More listening impressions through a 93db/1w/m open baffle speakers and powered subwoofer. It has the signature of JLH 69 but everything is more. More extended bass, more smooth vocals and more extended high. The timbre of piano is very , very good . The ambient retrieval is also better. Big drums are protrayed well with the perception of the skin being hit and very nice reverberation of the sound around the recording studio. Vocal are more detailed and sound very human . It is more holographic. 3D and sound stage is lifesize with a walk through sensation. This is the most impressive aspect . Hope to start on the cap multiplier power supply soon. Shaan Thanks for the reply. See the attached drawing. Is this the correct wiring ? I was thinking of retaining the VR in the circuit and regulated the V in the + and _ power supply rail before the amp. In this way you can still adjust the Iq You are right, I am over the moon ! thank once again kp93300 |
#103 | ||||
![]() Quote:
Cheers.
#104 | |
You are posting wrong things in the wrong place. Please do not post anything off-topic, otherwise I will have to report your activities to the moderators.
SSA Important Post Links:- How SSA Works, Nico's SSA, Nico's Thoughts on SSA Sound, Alex's SSA Mono PCB, LC's Scope Traces, SSA BIGBT PCB, SSA High Power Low Zout PCB, PeeCeeBee, SSA Speed, Why Current Feedback, Why SSA Is Unique, 20 Reasons To Go For SSA Last edited by shaan; 18th April 2012 at 02:26 AM. |
#105 | |
Sorry you feel that way . I feel intimated by your credentials ! My electronic knowledge is limited to what I learn from this forum and people like Shaan. I am willing to learn any suggestions from you to improve my audio experience and diy knowledge. thanks kp93300 |
#106 |
So the direct coupled version has been confirmed okay as well as the normal cap coupled DOZ. I was wondering whether the direct coupled one would do the same in other diyer's case as it did for me. Let us see who's the next happy guy to have built a DOZ himself.
cheers...
#107 |
I add the zener described in post 103 and Iq is much more stable --between 1.7 to 1.8 amp depending on ambient temp.
There is added benefit as the output transistor temp is more predictable --between 50 to 55 deg c in non air con room with ambient temp of about 30 deg c. One channel when into oscillation last night and thanks for the speaker protection unit ![]() After trouble shooting for 2 hours notice a poorly soldered resistor . Still having a honey moon with the amp ![]() :regards kp93300 |
#108 | |||
![]() Quote:
#109 |
Hi
Last weekend one of my friend who owns audioresearch reference series gear and SF Ellipsa speaker comment very positively on the sound of the amp. I hope more will build it . Shaan, Are there any other trans with better spec than TIP 3055 ? My output tran is off board and easy to swap Eager to milk the maximum out of this circuit ! thanks kp93300 |
#110 | |
TIP35C = Better choice(monster with 25A collector current! WHOA!). MJL21194 = GREAT choice(LARGE TO264 body, better dissipation, 4MHz, perfect). 2SC5200/MJL3281 = Best choice(Bloody fast BJTs with close to perfect characteristics; BUT thermally unstable and might introduce parasitic oscillation. )cheers.
| Some problems with Death Of Zen | bezobraznia | Pass Labs | 22 | 25th March 2011 11:51 PM |
| death of zen | janey | Pass Labs | 29 | 16th September 2009 08:59 PM |
| Choosing speakers for Death of Zen | starbase218 | Multi-Way | 12 | 30th January 2007 02:56 PM |
| Death Of Zen | DoomPixie | Solid State | 2 | 22nd August 2006 10:21 PM |
| Death Of zen On 15V supply? | DoomPixie | Solid State | 18 | 21st August 2006 09:47 PM |
