dc filter - Page 9 - diyAudio
Old 26th October 2004, 07:35 AM   #81
Electrons are yellow and more is better!
peranders's Avatar
I work with relays at work I even sell them, so horrible is a strong word. The relay, depending of design has hysteresis, more or less. Those with very little hysteresis, this kind of circuit is not very suitable but for a "normal" relay it will work rather OK but I prefer they way I have solved this problem.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 26th October 2004, 08:02 AM   #82
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb Simple circuit
Attached a very simple circuit that is working since 29 years with a 1k5 Watt transformer.....(NOT a toroid BTW!) Of course this is a AC relay.
Old 26th October 2004, 10:00 AM   #83
Sorry to use a strong word! The fact that wuffwaff's amp hasn't allowed the blue smoke to escape goes to show that it's a good 'un and that I'm maybe too quick to condemn something that doesn't look good on paper.
Old 26th October 2004, 03:35 PM   #84
Claus is offline Claus  Denmark
I have been using a circuit similar that from Elso for more than 12 years on my Futterman otl3e clones. Powering a 1000VA Toriod transformer up. I never had a blown fuse.
Simplicity at its best.
Claus
Old 5th November 2004, 12:21 PM   #85
wuffwaff's Avatar
Originally posted by Eva
I calculated 1.000uF for 200W maximum output @230V input [I tested a 750VA toroid but I had nothing at hand to dissipate more than 200W]. For higher power output it would be also a good idea to use diodes rated at a higher current than 1N4007 since they will have to pass all the load current in case of capacitor failure or excessive voltage swing
Hi Eva,
Just a question, did you calculate 200watts for two 1000uF caps back to back? How did you calculate this? I looked at average current, multiplicated by three and compared to the ripple current possible. This sort of fits but not exactly.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 15th January 2005, 12:02 AM   #86
Taffi is offline Taffi  Norway
Have been listening to DC and amp buzzing all night and had enough
Something has to be done NOW!
Found 4pcs Rifa PEH 169PO5100Q.
10.000uF, 100V laying around.
Is this enough to stop the DC or do I HAVE TO use diodes too?
As I have two different lines (balanced 230V as we have it in Norway and Albania) I wonder if these 4 caps would be enough for both lines?
And how should I connect them?
Are the polarty important?
Old 15th January 2005, 07:03 AM   #87
peranders's Avatar
How much capacitance you need is determined by the primary current and diodes are good as transient protection.
You have to put these caps i series and one wire is enough. I t has nothing to do with the absence of "neutral". If you as I or Lars Clausen have done it will work in 99% of the cases.
The caps you have got is extreme overkill (10 or 25 volt rating is needed) but will do a splendid job.
Old 15th January 2005, 08:11 AM   #88
By my listening experiences with serial condenser, in this case little bit " die " dynamic, which is probably caused by auxiliary impedance of this circuit. Much more better solution is using of " overkill " insulating transformer, which must be located in other room, 'cos in this case is humming too . Very elegant solution have Dieter Burmester, but it is patented ( I forgot number of this patent ).
Old 15th January 2005, 05:26 PM   #89
If I use only one cap wouldn't it be possible that I still could get DC between the other phase and ground?
Old 15th January 2005, 06:54 PM   #90
peranders's Avatar
Remember that the primary winding has only two wires and it's enough to have some in series with one of them.
If you want inspiration you can check my filter or Lars Clausen's.
My and Lars' solution is at least much cheaper than Upupa's
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 01:27 AM
Just one big filter cap or more smaller filter caps ... beppe61 Power Supplies 2 18th July 2006 05:46 PM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
chassis-mounted filter or IEC plug filter jarthel Solid State 7 11th March 2002 10:17 AM
Copyright ©1999-2017 diyAudio
