dc filter - Page 37 - diyAudio
Old 18th September 2013, 10:48 PM   #361
Originally Posted by Mooly View Post
Ideally you should measure no DC across the bridge. If you do, and if its below around 1.3 volts dc then the device is stopping that DC passing to the transformer. If its 1.3v or slightly more then it means there is more DC present than the filter can stop (unlikely).
I measure right now playing it low volume playing music....
i see no DC voltage just 00.00 on the multimeter....
Do i need this filter? being 00.00v on DC?
Think i can live without it? Or since it's made i can leave conected to the mains to the speaker and forget about it?
Old 19th September 2013, 07:19 AM   #362
Mooly's Avatar
You probably don't need it tbh. DC on the mains seems to affect large toroidal transformers mainly. If you regularly see no DC across the caps then its not really needed.
This explains it all in detail,
Mains DC and Transformers
Installing and using LTspice IV. From beginner to advanced.
Old 19th September 2013, 08:33 AM   #363
The box is safe enough if its all plastic.
Sure, no argument if that PVC box is in free air, it's as safe as any domestic wiring but I was actually concerned with the speaker box. I've been shown (couldn't economically repair) a couple of pairs of these popular, inexpensive, powered monitors and they were burned out internally. Luckily, no one was injured, but it seemed to me that plastic material, either damping or wrapping had sagged onto the hot electronics and eventually caused ignition. - Don't like 'em much after that.
Ian
Old 19th September 2013, 08:46 AM   #364
Mooly's Avatar
Ah, you mean the whole caboodle. It does sound a bit of a hazard from what you say. I've never seen or seen in one tbh
Old 19th September 2013, 11:43 AM   #365
Samson is not exactly inexpensive.... a lot of pro's use their stuff!
Compared to Mackie they are half the price, but the sound is good enough for me as the power they have.
When i play loud music, i mean Gig loud music on my house after 30minutes i always go check the cooler of the back of the speaker and it's barely warm.... i have that concern about it!
Now with the varnish on the transformers i will be super atented to that even more.... let's see... Hummm is still present but not that loud to concern... still a problem but i think my wife now can live whit it... and if "they" are happy it sure is down a lot!
Next stage will be the mu-metal or ultraperm around the transformer...
does anyone know if i can just glue the ultraperm foil to the transformer? Or should build a case of plastic around the transformer wrapeed then with the ultraperm or mu-metal foil?
Another concern... is wrapping the speaker box were the board sits with a material that will not get magnettization from the woofer to the electrics? Should i do that to? Or not needed for noise rejection and hum concerns...? maybe alluminum tape? is alluminum tape condutctive?
Old 5th November 2014, 09:54 PM   #366
Hi guys,
I have some questions regarding the DC-Filter, which I built from this site:
DC-Blocker - Scintilla-buizenversterkers
http://sound.westhost.com/articles/xfmr-dc.htm
Some of the filters use some capacitors in series, but some use the +-poles, some the --poles connected together, some of capacitors are connected between + and -. What is the right way to connect the capacitors in series?
Another question:
How to measure the AC's DC in the right way? When I measure between L and N, my meters jump between 2 and 30mV.
Many thanks,
Stammheim
Old 5th November 2014, 10:56 PM   #367
Mike B is offline Mike B  United Kingdom
Originally Posted by Stammheim View Post
Hi guys,
I have some questions regarding the DC-Filter ............
Another question:
Many thanks,
Stammheim
The filter design paper you have used - http://sound.westhost.com/articles/xfmr-dc.htm - explains it all correctly
Old 6th November 2014, 02:36 AM   #368
djk is offline djk
djk's Avatar
"How to measure the AC's DC in the right way?"
With a large resistor feeding a small integrator cap, 100K and maybe 10F.
Candidates for the Darwin Award should not read this author.
Old 6th November 2014, 07:19 PM   #369
Stamm,
I cannot see any advantage in using series connected capacitors facing in the same polarity.
Having series capacitors with opposite polarity can have an advantage if one believes there is significant leakage in the reverse direction when the voltage peak across the capacitor approaches 0.5Vpk. The forward facing capacitor limits the leakage current.
A parallel pair of opposite polarity seems to have even less going for it.
If you accept there is reverse leakage, then the opposite polarity capacitor offers no protection. The leaking capacitors just carries on leaking.
That website seems to be offering a solution that has nothing good about it.
Pity I can't read it, there maybe a clue to why he/she chose to do it their way.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 6th November 2014, 07:25 PM   #370
Mooly's Avatar
Just swipe the text and copy and paste it into an online translator (Bing or Google) if you haven't the accelerators installed to do it from your browser.
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 10th February 2008 12:38 AM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 02:27 AM
Just one big filter cap or more smaller filter caps ... beppe61 Power Supplies 2 18th July 2006 06:46 PM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 02:12 PM
chassis-mounted filter or IEC plug filter jarthel Solid State 7 11th March 2002 11:17 AM
Copyright 1999-2017 diyAudio
