Dual Power supply for my pre-amp
Old 29th February 2012, 08:08 PM   #1
SLAK is offline SLAK
Default Dual Power supply for my pre-amp
Greetings to all the members,
I need help to build a dual power supply for my pre-amplifier board which requires 22VDc (Max) for good operation.
The transformer which i have is a toroidal 50VA with Secondary output of 18v-0-18v.
PCB board that i have with me has been designed as per the schematic i have attached with this post.
I Request kind Members to Please recommend the components i hould use to receive the Maximum output of 22VDc & Best power filtering from this Circuit.
Any Kind advises will be deeply appreciated. Thank you.
Best Regards.....
Old 29th February 2012, 08:20 PM   #2
pdul is offline pdul  Denmark
How much current do you need?
Old 29th February 2012, 08:24 PM   #3
You can buy some cheap boards for something like this on Ebay
Old 29th February 2012, 08:27 PM   #4
About 1 amps is enough.
Old 29th February 2012, 08:30 PM   #5
I bot the Power supply PCB from ebay, but for some reason the output from that board is 42VDc where as the input is 18-0-18AC, may be i need to change the components on the board.
Old 29th February 2012, 08:30 PM   #6
You can obtain +-21v well regulated supply with up to 1,5 amps with this setup, with 18-0-18v ac with this setup
Old 29th February 2012, 08:33 PM   #7
even at the best and without regulation you can only get around 24,2v +- out of the setup you have shown
Old 29th February 2012, 08:37 PM   #8
18*squareroot of 2 - 1,2v drop in the rectifier
Old 29th February 2012, 08:41 PM   #9
Well that is what i Expected when i built the PS today, expected the supply to be max 24VDc, but i was shocked to see that the output is 42VDc where as the input to the board is 18-0-18ac, i have never come across this type of problem.
Old 29th February 2012, 08:46 PM   #10
This is how it looks. I just build one for myself to use for experiments
Dual Power supply for my pre-ampHide this!Advertise here!
Phono-pre-amp+power supply pcb Roushon Analogue Source 41 15th August 2011 01:23 AM
Seperate power supply for pre-amp section in integrated amp? KevinLee Solid State 8 2nd February 2008 11:20 PM
Supply for dual mono pre-amp Tex Houston Power Supplies 3 17th May 2007 10:26 PM
Using power supply to power pre-amp? preiter Chip Amps 4 11th May 2006 01:52 PM
