Dual Power supply for my pre-amp - Page 3 - diyAudio
Old 29th February 2012, 08:37 PM   #21
Originally Posted by pdul View Post
What is the voltage of your capacitors?
El caps= 2200uf 50volts x 4caps
Ceramic Caps= 0.1uf 63volts x 6 caps
Old 29th February 2012, 08:38 PM   #22
pdul is offline pdul  Denmark
They should be ok then
Old 29th February 2012, 08:40 PM   #23
This thread is running in Powersupply too
Old 29th February 2012, 08:41 PM   #24
The only question would be were your power supply caps over stressed? Most electrolytic caps have a reasonably large over voltage margin. Since you did not indicate that the power supply caps exploded, distorted shape, made a nasty smell or gushed cap juice all over your board. If your caps are rated for something close to 46 v and you didn't let the caps cook at that voltage you should be fine. But if it makes you fell better change them out. As I said it depends on the voltage rating on the caps used. If the caps you used were rated at 50v then you are good. Most caps over voltage rating is between 50 to 25 percent.
Old 29th February 2012, 08:49 PM   #25
Yes, apologies for that, i just dont know how to delete the thread over there.
At first i posted the thread here, then i realized that i should have posted in the POWER SUPPLY SECTION. It seems i made a similar mistake with posting threads as i did with my Power supply.... looks like I need a Break...
Old 29th February 2012, 09:04 PM   #26
Old 29th February 2012, 09:50 PM   #27
Just Checked with the correct connection, everything seems to be working fine.
Thanks PDUL & ANDY BARTHA.
Phono-pre-amp+power supply pcb Roushon Analogue Source 41 15th August 2011 12:23 AM
Seperate power supply for pre-amp section in integrated amp? KevinLee Solid State 8 2nd February 2008 10:20 PM
Supply for dual mono pre-amp Tex Houston Power Supplies 3 17th May 2007 09:26 PM
Using power supply to power pre-amp? preiter Chip Amps 4 11th May 2006 12:52 PM
Copyright 1999-2017 diyAudio
