Dual Power supply for my pre-amp - Page 2 - diyAudio
Old 29th February 2012, 08:47 PM   #11
What it is the Ac input voltage for the transformer? Maybe your using a 120 volts AC input transformer in a 220 Ac.
Old 29th February 2012, 08:49 PM   #12
pdul is offline pdul  Denmark
Maybe you have connected the trafo wrong. Are you shure you have measured both rails ?
Old 29th February 2012, 08:52 PM   #13
Measure the AC voltage going to the bridge. If the AC voltage more than 20 something than you are using 18v to 18v taps for a total of 36v. Wire up the transformer from one of the 18v taps to the 0v center tap. This will drop your voltage by half since you are only using one of the two winding available.
Old 29th February 2012, 09:03 PM   #14
No, Here in My city it is hard to find a Transformer with primary 120volt, I am 100% sure that the Ac input for my trans is 220v because i needed it that way.
Old 29th February 2012, 09:05 PM   #15
Connection is Correct,, Yes i have measured both the rails.
Plz let me check again
Old 29th February 2012, 09:22 PM   #16
My Bad.... It seems i made a mistake while making the connections, Connection was as Shown below.
Trans AC1 (18v) -------->> PCB AC1 in
Trans 0volt -------->> PCB AC2 in
Trans AC2 (18v) -------->> PCB 0v in
Now i have disconnected the bad connections. Before I make the correct connections, does any one think that i might have some how damaged the transformer because of the bad connection???
Old 29th February 2012, 09:26 PM   #17
Transformer should be fine
Old 29th February 2012, 09:28 PM   #18
Old 29th February 2012, 09:30 PM   #19
Thats good to know, so should i be worried about some faulty component.
Old 29th February 2012, 09:33 PM   #20
What is the voltage of your capacitors?
Phono-pre-amp+power supply pcb Roushon Analogue Source 41 15th August 2011 01:23 AM
Seperate power supply for pre-amp section in integrated amp? KevinLee Solid State 8 2nd February 2008 11:20 PM
Supply for dual mono pre-amp Tex Houston Power Supplies 3 17th May 2007 10:26 PM
Using power supply to power pre-amp? preiter Chip Amps 4 11th May 2006 01:52 PM
Copyright 1999-2017 diyAudio
