30k builders needed
This is another product of the formula . Data is required. Once you build the amplifier, simply post your findings in this thread. The formula indicates you will like it. Did you ? If you are looking for adventure and love to work with amps you are encouraged to join this thread, contribute by building the amplifier and posting your pictures and comments. Contribute to the state of the art
kind regards,
Harrison.
kind regards,
Harrison.
I have just found another thread dealing with that, hope PASS can tell us more
http://www.diyaudio.com/forums/solid-state/26043-thermistor-use-power-amp-bias-servo-circuit.html
draft
- HAL OPB amplifier
