HAL OPB amplifier
HAL OPB amplifier
Old 5th October 2012, 03:20 PM   #31
OnAudio is offline OnAudio
Originally Posted by evette View Post
Keep it going Mr. Harrison. Evette
Thanks Evette
onaudio.herokuapp.com
Old 30th October 2012, 07:06 PM   #32
Hi all,
Looking for volunteers. Kindly lay out this amplifier for me.http://www.harrisonaudiolabs.com/Amplifiers/OPB/OPB.pdf I love your team work. Alex have you laid it out yet ? Has anyone seen Drowranger ?
kind regards,
Harrison.
Old 30th October 2012, 07:24 PM   #33
lineup is offline lineup  Sweden
lineup's Avatar
OPB uses a clever design. Instead of trying to beat OPamp input with discretes, this amplifier uses opamp with very low distortion.
This is in my book a good idea.
The output uses some voltage amplification to give opamp a target within opamp supply range.
I have done an amplifier like that. Built it too. It sounded just fine. My output was running in pushpull Class A.
lineup
Old 3rd January 2013, 10:38 PM   #34
Default conceptual quick layout
Sample quick layout
Old 20th January 2013, 08:24 PM   #35
ronnydepony is offline ronnydepony  Belgium
First try, far from complete, but can give an idea
Old 20th January 2013, 08:41 PM   #36
evette is offline evette  Canada
Send a message via Yahoo to evette
Looks Good. Evette
Old 20th January 2013, 10:23 PM   #37
WSJ is offline WSJ  United States
WSJ's Avatar
The layout looks great.
It would be great to add the +/- 15 volt zeners and resistors.
I also like the RCA connector for the input, see one on my Avatar.
Only $1.73 from Digikey.
901 Keystone Electronics | 901K-ND | DigiKey
Old 22nd January 2013, 09:43 PM   #38
Thanks for joining us. The first step is all it takes for a great result to come up . To better handle the darling tons temperature control the quick layout has two specific bias control transistors on heat sink. Check the quick layout .
You could bring in the +/-15 onto board or you could extract it from the main supply. The quick layout uses the first option, this really depends on whats at hand. The heavy current tracks need to have their proper width
Old 24th January 2013, 06:09 PM   #39
Had some time for an upgrade
Ronny
Old 24th January 2013, 09:50 PM   #40
WSJ's Avatar
Ronny
The layout looks good. It would be great to have some unused pads to the left of the +/- 15 Volt connector to mount zeners, resistors and caps. It looks like enough space if the parts are mounted on end. I use 3-4 pad groups to allow 2-3 component leads and a wire to make a junction.
The top mounting holes look very close to the traces. I don't see the signal pad for the RCA connector.
Here is an example; the DIP package spacing is not needed for this application.
HAL OPB amplifierHide this!Advertise here!
HAL PREAMPLIFIERS OnAudio Solid State 86 19th March 2012 06:47 AM
HAL SYMFET OnAudio Solid State 23 21st January 2012 06:54 AM
A certain HAL Amplifier OnAudio Solid State 0 23rd November 2011 03:41 PM
HAL-O Damping Instruments Tazzy Tubes / Valves 7 14th October 2004 02:24 AM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Copyright ©1999-2017 diyAudio
