Just for reference, I managed to acquire the schematics for phonic P8A active monitors which I am currently rebuilding and tuning. They didn't send me the full service manual but chances are the other models (P5A, P6A..) use the same or similar amp.
Also from googling and inspecting the closeup images there is a reason to suspect that older Behringer monitors (B2030A and B2031A, not sure about B303X series) differ very little from these - they all use three TDA7293 chips and nearly identical eq section. I will send the schematics to anyone interested if you pm me your email. K.
Nothing is as simple as it seems Last edited by wxn; 25th February 2012 at 08:55 AM. |
#2 |
Hello I have a phonic p8a the transformer has burnt but do not know where the tension and intensity of secondary thanked the scheme if possible
thank you |
#3 |
Yeap, I'm having a problem with one and trying to troubleshoot it. Would really appreciate the schemo too, if possible. Thank you!
#4 |
I know it's been a while since you posted this, but I just picked up a set of the P5As and could really use a schematic. Even if it is not exactly the same, hopefully it will be close enough. Would it be possible to send me a copy? Much appreciated!
| phonic xp 5000 schematic | C3PO | Solid State | 17 | 8th June 2012 12:09 PM |
| schematic of Phonic PWA 2200 power amp? | richi | Solid State | 0 | 4th October 2011 09:27 PM |
| phonic xp 3000 schematic | C3PO | Solid State | 2 | 17th October 2010 02:41 AM |
| PHONIC PWA 2200 schematic Needed | bob o mastoras | Solid State | 2 | 25th November 2009 08:23 PM |
| Phonic MAR2 Schematic Needed | RAZAMA | Solid State | 2 | 6th July 2009 05:48 PM |
