Another simple DC protection
Old 5th September 2011, 02:02 PM   #61
Esperado is offline Esperado  France
Banned
Originally Posted by Mooly View Post
this working prototype aims to eliminate that delay by comparing input and output of amp. If there is a difference... the relay trips.
Oh, gosh, i had exactly the same idea 20 years ago, and that's how work my own protection since those years.
A working amplifier must have the same signal (scale apart) out and in.
And this gives a lot of advantages. it protect from everything: Clipping, HF, oscillations as well as DC and short circuits on the loudspeaker line. And it is instant.
The only problem is, because the complex charge witch is the loudspeaker and its motional signals , and because the phase switch that the amplifier can introduce, we need to adjust a gate for the relay does not switch-on at each drum kicks.
On my side, i do not introduce any temporal delay before protection switch on. Just my circuit authorizes the good amount of errors from the loudspeaker line. But i have a delay witch keep the protection on for 3s after the cause of the trouble had disappear .
By default, on my circuit, the Loudspeakers are not switched, and i have an additional circuit witch wait 5sec after power on operations before the relay can switch them on. And cut the relay instant when power off.
In fact, when you power off, first the relay cut the loudspeakers, then the power relay switch off the power.
When you power on, there is a resistance in serial with the PSU condensers to avoid huge transients. After 2sec, a relay short circuit this resistance. After 5 more seconds, the power is send to the loudspeakers protection relays. All that use only a quad OP AMP, 3 transistors, few resistances and condensers, and 3 LEDs shows the sequence and states (power on > condensers on > loudspeakers on).
Works like a charm, with not a single "clic" during all those years.
Old 5th September 2011, 03:02 PM   #62
Bigun is offline Bigun  Canada
Bigun's Avatar
Esperado, that sounds like a great circuit - can you post the schematic. I'm looking for a speaker protection circuit and this sounds like a good candidate.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 5th September 2011, 04:07 PM   #63
Banned
I'm building a new system, so i will post the shematic and circuit board design within the next month.
It will be here:
http://www.diyaudio.com/forums/digit...m-project.html
If you are in a hurry, i can open my actual amp to recover my original schematic with precise values, but i feel lazy ;-)
Old 30th September 2011, 10:20 PM   #64
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
After building the DCB1 buffer (and not being able to go back due to the big improvements relative to my previous line buffer that uses a cap in the output) I am worried that a PSU failure might cause excess offset and kill my speakers (or worst).
I read a lot and only found designs and ideas of protections that use relays on the speakers.
Is it possible to implement one of these designs to control relays between the buffer output and the power amp ?
I am using a complex simetrical PSU and am afraid of possible failure (due to housekeeping damages, and not to the implementation or design).
RC
Old 1st October 2011, 09:11 AM   #65
R.I.P.
you can fit a mute to the output of the DCB1,
or fit a mute to the input of your power amps.
or fit a cutoff in the power supply rails of the power amps,
or fit a crowbar to the output of the power amps.
All of these avoif placing any sound interfering relay in the speaker lead.
Finally a cutoff of amplifier output.
There is a recent discussion on replacing relays with FETs to improve the reliability of the cutoff and avoid some of the sound degrading properties of relays.
regards Andrew T.
Old 1st October 2011, 01:07 PM   #66
Banned
The purpose of a protection is to... protect. An amplifier can broke itself for a lot of reasons, then burn your valuable speakers. So there is two places you can only put relays, it is between power supply and amp, or between amp and loudspeaker. The first one can be ok in case of faillure, but not protect against power-on/off noises and DC . Devinitively, the best place is between amp and Loudspeakers. Of course, you can add an other relay in the Amp input, but why ? A well designed amp is able to manage any kind of signal at the input up to peak +-15v if no charge. And it is the max that can feed your preamp. More, you need to continue to compare the signal when the protection is "on", that suppose your amp continue to amplify the input signal: the protection will stay "on" until the input signal returns to a normal level/frequency range.
Old 1st October 2011, 03:13 PM   #67
CopperTop is offline CopperTop  United Kingdom
Quad fitted a triac-based crowbar circuit to the Quad 405. It uses a Silicon Bilateral Switch to trip the triac at about 10V or so, with an RC delay. I don't know where to buy an SBS in the UK, but the data sheet for the device gives a transistor equivalent. I built it, and it seems to work fine. However, from what I can tell, I notice that Quad now doesn't bother with such a circuit, using a floating ground PSU topology that inherently protects against DC faults (although I think the energy in one of the caps has to discharge through the speaker).
Am I correct in thinking that series relays are not so good for this application because the contacts have a tendency to weld closed when attempting to open them during a high surge of DC?
Old 1st October 2011, 03:41 PM   #68
Banned
I don't think so, if the relay is correctly dimensioned and their contact well protected. But you can think about a more complex circuitry: Mos fet for switching followed by the relay, relay first followed by the Mosfet when protection switch on. Here the relay will be there only for reducing the serial impedance of the MosFet and will not deal with noticeable current or tension. I had tried-it. Not a difference in sound for an increased complexity, and never a problem of relay during 2 years on my personal 2x140W amp with a lot of output short circuit tests: forgotten on my side.
Old 1st October 2011, 03:50 PM   #69
nhinstruments
RCruz's Avatar
I need a protection on the output of the DCB1 because I want to use it in different amps.
I am using a simetric PSU (+-10V)... Is it easy to design a sensor that detects failure in one of the PSU´s (+ or -) and cuts out the output ?
RC
Old 1st October 2011, 05:18 PM   #70
Banned
A simple comparator between input and output signal of the amp does-it instant, as well as HF, clipping, switch-on " clocs" and DC errors. It is global !
Another simple DC protectionHide this!Advertise here!
simple loudspeaker protection needed Flavio88 Multi-Way 0 11th January 2007 11:34 PM
A simple speaker protection circuit Russ White Parts 38 11th December 2006 01:39 PM
speaker protection (OR) overload protection myanmar Solid State 7 13th July 2006 08:21 AM
My first simple mains conditioner/surge protection: maxlorenz Parts 29 7th January 2006 05:53 PM
simple super-tweeter protection circuit Macdude443 Multi-Way 3 22nd December 2004 05:16 PM
