Powered up amplifier without one of the psu rails connected - now distorted channel - diyAudio
Old 22nd February 2012, 06:53 PM   #1
Exclamation Powered up amplifier without one of the psu rails connected - now distorted channel
Hi! I have a simple question:
I (acidentally) used an amplifier without one of the power supply rails connected and now one channel is not working right. Is this a "usual" problem? Will doing what I did typically destroy the amplifier?
More in-depth:
I was cleaning up a very dirty vintage amplifier with a typical power supply. The amplifier had a fuse for each rail. I polished up these fuses, and destroyed one of them in the process without noticing.
After I was done, I tried out the amp and one channel was heavily distorted, practically nothing but noise coming out of it. DC offset was extremely unreliable, varying from around 4 mV to a few volts! Moving the volume control was causing the fluctuations. I I measured the voltages on the power supply - 40 VDC on one rail, and 0 on the other. Checked the fuses and noticed the one I had destroyed. Replaced it and now the voltages are normal. 40 VDC on both sides.
Now that channel is not as distorted. It works but there is still a lot of noise. Like someone is blowing into a microphone - that kind of noise. The DC offset problem persists, especially when using the volume control.
The amp was fine before I touched it. DC offset was about 10 mV on both channels.
There is no service manual to be had, this is a very uncommon amplifier and nobody knows who designed it. It appears to be quite simple, however. It uses STK 0050 modules, but only six pins (out of ten) are connected to the pcb.
Sorry for the long post.
Old 22nd February 2012, 07:39 PM   #2
Addition: Here is the pinout for STK0050
Pin 1: Input pos(+)
Pin 2: Vcc neg(-)
Pin 3: Output
Pin 4: NC
Pin 5: NC
Pin 6: NC
Pin 7: NC
Pin 8: Output
Pin 9: Vcc pos(+)
Pin 10: Input neg(-)
Could this mean that both STKs are damaged?
EDIT: I measured Pin 3 and Pin 8 towards ground, on both STKs. I got 1550 ohms on them all.
Old 22nd February 2012, 07:45 PM   #3
merlin2069er's Avatar
Send a message via MSN to merlin2069er
those ic's aren't too expensive, try replacing them.
Sanyo STK0050 Audio IC power amplifer | eBay
Old 22nd February 2012, 07:55 PM   #4
oh, you should try swapping your speaker outputs around, you might have damaged a speaker.
Old 22nd February 2012, 09:37 PM   #5
I tried replacing the differential pair on the defective channel. The originals were poorly matched (400 and 470 hFE). Now it got better, but the noise was still there... until I fiddled with the selector switch a bit. Now it works. Damn, I should have tested that more thoroughly right away. I always panic when I get problems... and forget the obvious stuff. Sorry about making this thread.
Old 23rd February 2012, 03:34 AM   #6
That is also an experience to learn from, for others. No need to be sorry.
Gajanan Phadte
Old 23rd February 2012, 07:05 AM   #7
EDIT : Basically said the same thing as poster above...
Old 23rd February 2012, 03:06 PM   #8
Thanks guys.
I cleaned the selector switch very thoroughly and now everything is fine.
Just one thing.
When I turn it off, there is massive dc offset on both channels with no load connected. With speakers I get some crackle in them, and then that's it. The amp has no protection circuit. This I suppose should be normal, but I still haven't encountered an amp this bad before (usually there will just be a short snap when turning off). Also, the bad dc offset remains when no load is connected. I plugged it in again today (unused since last night) and it still had about 200mV on both speaker outputs.
Old 23rd February 2012, 03:58 PM   #9
Bigun is offline Bigun  Canada
Bigun's Avatar
'noises' at turn off are pretty common - they usually measure as large dc offset on the output but generally they are of no concern unless you find it irritating. You should probably check it with a load connected (a resistor rather than a valuable speaker) as it's all too easy to get large voltages when no current is drawn whereas with a load you may see a much smaller offset which may put your concerns to rest.
A steady dc offset of 200mV is a bit high (20mV would be good) and it should be something you could adjust out - would have to see the schematic to advise the best way. But I don't think it's high enough to damage a speaker or have much impact on the sound.
p.s. tracing out the schematic by looking at the wiring and the pcb could be a good learning opportunity.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 25th February 2012, 02:10 PM   #10
Sorry, I was a bit unclear. I meant that the dc offset is measured at 200mA after turn off, when no speakers have been connected.
During normal use, dc-offset is around 1-10mA. Quite good.
With speakers connected, the juice runs out right away and there is no dc offset after turn off. What I was curious about is what could be causing the high dc offset to remain "forever" if there were no speakers connected. I am going to replace all the capacitors in this amp, as I always do with vintage equipment. Perhaps that will change things. Anyway, this is a non-issue, really. I'm just thinking out loud, sorry.
The tracing idea is an interesting one, and it didn't cross my mind before. That sounds quite interesting (and certainly educational)! Thanks!
Punch 500a2 distorted channel chipper Car Audio 62 21st March 2011 09:02 PM
amplifier works connected to PC .. but not when connected to car radio anwaypasible Analog Line Level 1 2nd March 2011 07:42 PM
Three Channel Amplifier w/PSU The Saint Aussie Amplifiers 8 16th December 2009 10:12 PM
ppi pc2150 distorted right channel 67elcamino Car Audio 16 29th August 2009 06:46 AM
Help!! Right Channel Freq distorted. TPC Tubes / Valves 3 16th January 2003 02:27 PM
Copyright 1999-2017 diyAudio
