university sound a300/1 wired for stereo?
Old 22nd February 2012, 02:36 PM   #1
scottwilson is offline scottwilson
Default university sound a300/1 wired for stereo?
I have come accross 5 university sound a300/1 amps. I understand they are only mono amps, but is there a way using another device to connect this up for stereo music?
Scott
Old 22nd February 2012, 07:10 PM   #2
Ian Finch is offline Ian Finch  Australia
Hi Scott, welcome to DIYAudio
Simply, you need a stereo preamplifier to provide the ganged controls, input selection and suitable input matching etc. that integrated amps have but obviously, all separate power amplifier systems will need them in some form too.
A stereo preamp will have line level outputs for a pair of your right and left designated channel amplifiers. This will make what are popularly known as monoblocs. Instead of twin signal lead, use separate ones to each amplifier input or simply peel a pair apart.
It's not always the case that inputs suit what we want to match to, so it would be a good idea to locate at least a User Manual on the net (possibly a free download) to check that a line level input is available, so a direct connection to the amplifier input can be made. The power amplifier output arrangements should be obvious. Good listening!
If only I had listened....
university sound a300/1 wired for stereo?Hide this!Advertise here!
Help for Cambridge A300 please Justcallmedad Solid State 73 27th September 2014 12:51 PM
Turner A300 Stereo Power Amplifier poynton Solid State 5 25th July 2011 09:19 AM
University Sound 1790 Testing ewhiz Solid State 3 19th September 2010 03:57 PM
Stereo amp parallel wired to mono - possible? hasselbaink Tubes / Valves 14 11th April 2010 02:07 PM
University Sound compression dirver, model T50 ? Empee Multi-Way 0 4th April 2007 12:42 PM
