BURSON SINGLE AUDIO OPAMPS ! ONE OF THE GREATEST !
Old 21st February 2012, 08:16 AM   #1
vmed_cha_gr is offline vmed_cha_gr  Greece
Default BURSON SINGLE AUDIO OPAMPS ! ONE OF THE GREATEST !
I modified my second Audiolab 8000p using Burson Audio opamps as a direct replacement over the Burr Brown opa134 it had.
I recommend them 100%. Results are outstanding, it is a killer amp now. Total control in every sound aspect.
Old 21st February 2012, 09:34 AM   #2
djk is offline djk
djk's Avatar
$72 each seems a bit much for what it is.
Candidates for the Darwin Award should not read this author.
Old 21st February 2012, 09:40 AM   #3
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
Also had the pleasure of using those discrete opamps, excellent sonics but the turn off is their a bit pricey.
Old 21st February 2012, 10:11 AM   #4
sgrossklass is offline sgrossklass  Germany
Are these the ones that Samuel Groner tested (and found identical to audio-gd OPA-Earth)? Those didn't measure particularly well, and "downgrade" would seem to be a more fitting term.
Old 21st February 2012, 11:05 AM   #5
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
No thanks. Everyone has their favorite, but at $2.50 the LME49990 can't be beat IMO.
Old 21st February 2012, 11:09 AM   #6
UV101 is offline UV101  England
UV101's Avatar
Have you actually listened to them?
I have several and they are very good, definately not a downgrade.
I also use LME49710HA (and 20HA) and these are better VFM than the discrete if not quite as good. The NA versions are exceptional VFM!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 21st February 2012, 11:13 AM   #7
I think the price is ok. It is a little bit higher than Burr Brown OPA627 but they come matched & with a lifetime warranty ( all you need to do is post your project to their email address). It took me 30 minutes to solder them . Differences are noticeable immediately.
I have two power amps which are exactly the same so the comparison was accurate.
Old 21st February 2012, 11:35 AM   #8
Boscoe is offline Boscoe  United Kingdom
How does changing out an op-amp give control over sound?
Audio projects and more: gswdh.co.uk
Old 21st February 2012, 11:45 AM   #9
UV101's Avatar
Are you sure you want to be asking that?
Its a signal amplifier in the audio path. Dependant on design, it could be a unity gain buffer, an amplifier or form part of a filter circuit. Either way the audio passes right through it.
Old 21st February 2012, 11:48 AM   #10
It is quite common to spread rumours that he found them identical to audio-gd OPA-Earth.
What i'm trying to say is that : In 2 identical power amps, one has the opa627 installed & the other has Burson inside. The one with the Burson outperformed the one with the well known 627 (which is still a good one).
You have to do it yourself in order to make conclusions.
I've done it & i recommend it to you .
BURSON SINGLE AUDIO OPAMPS ! ONE OF THE GREATEST !Hide this!Advertise here!
Burson audio Opamps extender cable je5u5facedassassin PC Based 7 15th December 2017 08:38 PM
Using burson opamps on an old Sumo nine omc Solid State 10 4th October 2011 01:26 AM
burson dual discrete opamps version 2, plus burson shunt regs qusp Swap Meet 9 8th April 2011 01:13 PM
FS:Burson single opamp x 4 Thomas Giz Swap Meet 5 26th October 2010 06:40 AM
Burson Dual Opamps (EU) Slash47 Swap Meet 6 18th April 2010 11:09 PM
