aragon 4004 mk2 schematic needed - diyAudio
Old 20th February 2012, 04:10 PM   #1
Default aragon 4004 mk2 schematic needed
hello all- i have an aragon 4004mk2 that suffered a spike when the negative power supply rail on my preamp failed. 1 channel popped a fuse and i found a couple of driver transistors shorted and a shorted current regulating diode.
it looks like i need a schematic to proceed further.
if anyone out there can help, i would be most appreciative.
regards, leapingknome
Old 20th February 2012, 09:17 PM   #2
Nrik is offline Nrik  Denmark
Check
Henrik
Old 20th February 2012, 09:40 PM   #3
Originally Posted by Nrik View Post
Check
I only very briefly examined the schematic, but I did note an interesting design decision. The inclusion of 680pF capacitors C2 and C12 seems odd, as they are located inside the error correction loop and will shunt high-frequency currents to outside the loop. The input stage error amplifier will attempt to correct for the lost loop current, decreasing high-frequency feedback and, I should think, increasing high-frequency distortion. I would think that Cdom caps., C3 and C13, should be sufficient for stability, unless they are undersized. Perhaps, the designer felt it simply sounded better this way.
Ken
Old 21st February 2012, 12:39 PM   #4
thank you for the info.
Old 17th February 2013, 03:43 PM   #5
Sorry to revive an old thread but I have a 4004 MK I that has a hum in both channels but only when connected to ANY preamp via the RCA inputs. If the amp is powered on and connected to speakers and not connected to a preamp or source, no hum. If the amp is then connected to ANY preamp including a 100% dc ipod nano touch as a source, both channels have a clearly audible hum. Sounds like 60 hz. I have tried 3 different preamps all with the same result.
Any ideas? The amp still plays and sounds great, just hums with a pre or source connected. Also the toroids do have an audible buzz when powered on. i have tried a DC blocker with no results. This amp ran fine in a friends rig for years with no hum from the speakers even though the toroids have always had a low buzz. Now in my rig it hums. Both channels.
Old 29th July 2015, 06:34 PM   #6
I have an Aragon 8002 with an intermittent problem. Once in a while it starts making a crackling noise on its left channel that goes away as soon as I power cycle it. Any hints on what could be going ?
Anyone has a schematics for the ARAGON 8002 so I can ask my technician to look at the problem ?
Thanks a lot,
Andre
Aragon 4004 slow relay problem Colin151 Solid State 2 3rd December 2013 09:06 AM
Aragon 4004 power amp channel imbalance David120 Solid State 7 12th August 2011 05:46 PM
Classic Aragon (2004, 2004 MK II, 4004, 4004 MK II ) problems, experience and repairs MagicMarksy Solid State 1 22nd May 2010 03:36 PM
Update of the Aragon 4004 mightydub Solid State 10 5th November 2009 06:02 AM
Aragon 4004 ben goh Solid State 0 3rd May 2003 03:55 AM
Copyright 1999-2017 diyAudio
