I have read numerous threads about building a power line DC blocking filter but I am still looking for answers to some questions. I am building a RFI/EMI filter for the shack and am debating whether to include a dc filter with it or not. So -
How can you really detect if there is DC offset on the line ? I dont have a 'scope. Besides transformer buzz what other effect could a dc offset possibly have on the performance of the equipment - say an amp or a dac(read clocks and PLLs sensitive to voltage supply). How much offset is really something that needs to be addressed ? 0.5v ? 5v ? more ? less ? Last edited by percy; 21st February 2012 at 12:22 PM. |
#2 |
#3 | |
Typically one sees about 1V or less dc on mains, but of course that strongly varies. Hannes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2 transistor kits |
#4 |
I recommend you go onto Rod Eliots ESP site - he has a very good write-up on mains DC and a circuit on how to fix it.
I had this issue when I was in Japan, and my transformer rattled very loudly (2KVA torroid) - and it only happened when the gas dryer or dishwasher were running - seems the loads were very unbalanced. |
#5 |
I'm using a regular diode bridge and two antiparallel capacitors (as described by Rod Elliot) since a while. I have power supplies in wooden (speaker) enclosures, the boxes really emphasize the hum...
It works as expected, any toroidal transformer I connect it to instantly becomes dead quiet. ![]() I find it most impressing, though, that Elliot measures over 52VA idle losses in his 500VA transformer, of which more than 48VA were due to core saturation as a result of just 264mV mains DC! ![]() Cheers, Sebastian. |
#6 |
DC offset in your distribution line? So where would it come from? It would HAVE to be after the supply TX in your street - what possibly would cause this?
#7 |
Thanks.
Still seeking an answer to this question though - all of you who tried the dc filter and quieted the transformer might be able to offer some input on this. |
#8 | ||
What would cause the offset? All sorts of rectifying loads, motors, switching supplies, variable-frequency drive (VFD) circuits, etc. Quote:
OTOH, lack thereof could of course be beneficial to the supplied circuitry. Transformer buzz isn't quite the EMI source, I suppose. ![]() Cheers, Sebastian. |
#9 |
So it is a pulsed DC more or less? IN basic terms, if you were to supply a device which has a different power factor to the device consuming current only on one polarity then you wouldn't notice it?
#10 |
Any device which takes more current on one mains phase than the opposite phase creates DC on the mains. Basically this could be anything which has a directly-connected (i.e. no transformer) half-wave rectifier. In the past this would have been (in the UK) almost all TVs and many valve radios - fortunately back then there were few toroidal transformers to get upset by DC. My guess is nowadays it is more likely to be a large number of small devices.
The DC voltage you see happens because of two things: the transformer down the street is delivering 0V DC, the resistance in the wiring (and the transformer) gives a DC voltage drop. Hence you get DC. Because you need resistance to generate this DC voltage it probably means that the cause is near you on the mains - one of your neighbours, or possibly even in your own house! Not necessarily next door, but maybe three doors away as you will be on the same phase. |
| Max allowable DC offset for power amplifier | diy didi | Solid State | 5 | 8th January 2012 08:48 PM |
| DC offset in Class A SE Power Amp | ervinl | Solid State | 15 | 8th August 2010 10:07 AM |
| Audio line DC offset | foryourdemons | Analog Line Level | 3 | 27th March 2010 08:43 AM |
| DC offset after power disconnected | Pooley | Chip Amps | 10 | 25th September 2008 11:33 PM |
| DC offset on household ac line ? | percy | Chip Amps | 9 | 24th January 2006 09:30 AM |
