Old 15th February 2012, 11:40 AM   #1
Default Mackie 1400i hot light on
I got a Mackie for free that has a hot light on and high fan. Never worked on one before. The amp won't pass signal in this condition. No blown fuses no shorted outputs.
Any ideas?
Old 15th February 2012, 01:03 PM   #2
Check the bias stage. It might have a fault causing it to go into Class A mode.
Old 15th February 2012, 11:59 PM   #3
From the service manual.
1) "The hot LED lights to indicate that the amplifier has engaged protection due to heat sink or power transformer core temp"
2) "Extreme heat sink or transformer core temperature will activate OVER TEMP. U5A activates over temp if the LM35DZ detects temperature above 80 deg C.
Feedback resistor R137 rescales U5A voltage reference so that the heatsink must cool below 50 deg C before overtemp is deactivated. Overtemp can also be activated by the power transformer thermal breaker (via Q89). In either case, both channels are muted via D69 and D66."
Look for a fault around these components.
Old 16th February 2012, 09:58 AM   #4
The hot light is on immediately when the amp is turned on. No heat build up on the heat sinks per my infrared thermometer.
Old 16th February 2012, 10:25 AM   #5
Audio Junkie
Zero Cool's Avatar
I have worked on many of these. look for open resistors. they wont show any signs of failure but when you measure them, they will be open! also look for cracked solder joints. front left corner of the board if memory serves.
It's not about what you can BUY...It's about what you can BUILD!
Old 16th February 2012, 10:48 AM   #6
Are you talking the main board? or the small board on the other side of the heat sink that the fan is plugged into?
Old 16th February 2012, 11:22 AM   #7
I realise the hot light is on immediately when it is not hot. My post above indicates which components may be triggering the fault. For instance check for dry joints around the LM35, check the base voltage on Q89 to see if the power transformer overtemp sensor is faulty etc etc. It is either coming from the power transformer sensor, the heatsink sensor (lm35 on main HS, or dry joint around there) or the opamp which triggers the overtemp. Test R205 to see if it is to spec and test Q91 also. Post some photos of the board (even the small ne) if you like.
Old 18th February 2012, 11:40 AM   #8
Taking it apart right now. Will take some pictures of the board to post.
Old 18th February 2012, 09:39 PM   #9
Found R205 on the small board on the other side of the amplifier board. R205 was open so I replaced it. I checked the transistors on the board and they tested good checked remaining resistors and they were good. Plugged it in and noticed the transistors Q89,90, and 91 area were hot. Amp is still in overtemp state. Have not found the LM35DZ yet and will check R137
Old 18th February 2012, 10:25 PM   #10
Audio Junkie
Zero Cool's Avatar
yup small board! and I always find a problem on the main board too but i cant think of it at the moment. keep going you are on the right track!
F2 running hot(how hot is hot?) Aron Pass Labs 10 13th February 2009 03:42 PM
Hot hot ouch - rectifier Nordic Parts 9 8th October 2005 07:00 PM
Re-case a mackie 1400i cbecker33 Everything Else 1 11th January 2005 03:04 AM
mackie for sub amp cbecker33 Subwoofers 3 10th January 2005 04:27 AM
Wave av-8 hot hot ?? adharvey Tubes / Valves 13 7th October 2003 07:32 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
