Hello
I have a NAD C370 amp and i like it a lot but, a couple off months ago it started to fail. When i turn it on, i only have sound from the left speaker. The right speaker only connects after 3 to 4 min. Does anybody has a clue on this one? Thanks Mário |
#2 |
It could be a bad output relay. If you are using speaker A outputs, try moving the speaker wires to the B output posts. Select speaker B from the front panel and see if it still has a problem with the right channel.
#3 |
Hey hello Bill
Thanks for your answer. I´ve tried that but the problem is still the same. It cuts both right channels ( A and B outputs) Does the protection circuit has anything to do with this? Is there any common failure in any component? Thanks a lot Mário |
#4 |
The protection circuit should affect both channels.
You can get a C370 service manual at ElektroTanya | Service manuals and repair tips for electronics experts For protection circuit repair see pithed.org NAD C370 protection circuit repair (amp fails, goes into protection mode) |
| NAD C370 power-on problem | windfall123 | Solid State | 7 | 7th August 2011 11:25 AM |
| NAD c370 Amplifier. | Ronjakcs65 | Solid State | 0 | 7th April 2011 02:35 PM |
| Replacing CAPs in NAD C370 | silversweden | Solid State | 9 | 28th December 2009 07:36 PM |
| NAD C370 Diagnosis and repair help | cyteen | Solid State | 21 | 21st July 2008 03:48 AM |
| NAD C370 Volume Potentiometer fail | somelvis | Solid State | 4 | 15th July 2007 09:47 PM |
| Page generated in 0.07923 seconds (70.25% PHP - 29.75% MySQL) with 10 queries |
