It happened again last night, blew two channels. First time couple months back I blew a channel due to me shorting something out while adjusting bias. This time one channel blew after I played some music as loud as it could possibly get w/o hearing any distortion. Worked for a couple minutes and then FLASH, poof and its silent. This time it didn't take my speakers out with it, lucky me.
Clearly my speakers aren't the easiest things to play, my onkyo receiver also goes into protect mode when played at loud levels. What would be a good amplifier , I am just sick of blowing output transistors and I don't want to risk blowing my drivers again. I have aleph 2 boards completed, just need matching output devices and then its just a chassis work. Is there something else out there that I can look at ? thanks.
left lane is for passing, slower traffic keep right please. |
#2 |
Hi Jean,
First your "tag"... Right lane is for passing slow-movers who THINK they're entitled to the left lane. Secondly, your gear: to get an idea of your "loud playing", what's your Onkyo rated at (8 ohms) ? There could be three main categories for your problems. 1) HF oscillations causing heat dissapation which you can't hear. 2) Insufficient thermal compensation, causing thermal runaway in your output transistors 3) Insufficient number of output transistors / insufficuient heat sinking Option 1 is less likely, since your onkyo also cuts out with your speakers. If you've ever monitored the temperatures on your heat sinks or transistor casings, you should be able to determine whether it's 2 or 3 which kills your amp. What sort of power level was your last DIY rated (estimated) at (watt/ch), and how much heat sinking ('K /W) was applied? It's important to remember that you have a thermal resistance between the transistor casing and the heat sink, and between the transistor's semi-conductor and the transistor housing (enclosure). Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good. |
#3 | |
Hi Jennice,
#4 |
Are you trying to tell me you're pulling tough loads with an amp that has ONE output pair???
#5 |
Yep, its one tough amp
#6 |
I would double up on the output transistors. Look at Rod's article on safe operating area. Put some little heatsinks on the drivers too. Then crank it.
P.S. Thanks for the transformer. Its in a Zen 5.
MikeW |
#7 |
Hi Jean,
I guess we now know just how tough the amp is... Adding additional output devices will surely ease the load on the components for safer operation (and maybe you want to consider additional heat sinking?) However, some schematics easily allow for parallel output devices, others not as easily. You sound rather familiar with DIY'ing, so you should figure out. Otherwise let me know (if so, please provide a link to it). Jennice
#8 | |
Probably you've pushed the amp into clipping, causing too much heat dissipation or HF oscillation. Maybe a clipping indicator is also a good tool for you!! Anyway, double the amount of output transistors and place a simple limiter at the input. Best regards, HB. |
| Design Stable @ 1 Ohm Nominal? | J.R.Freeman | Class D | 30 | 27th August 2009 08:01 PM |
| TA10.1 2ohm stable??? | SAC | Class D | 7 | 26th June 2008 02:00 PM |
| Is this stable?? | Leolabs | Solid State | 1 | 27th November 2006 01:23 AM |
| Is this amp 2-ohm stable? | michal | Car Audio | 4 | 1st July 2005 04:59 AM |
| 2 ohm stable Symemetrical amp | halvardf | Solid State | 4 | 14th September 2002 04:16 PM |
| Page generated in 0.11882 seconds (80.95% PHP - 19.05% MySQL) with 10 queries |
