Power On.
Power On.
Old 23rd September 2003, 03:33 AM   #1
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Default Power On.
Does any one out there have a power on power off schematic that will drive a simple relay.
i would like to get some thing that i can have one switch but do both functions
one press for power on and one press for power off.
to activate a relay to turn on the main part of the amplifier.
any one help..
Please i lost my old one and now i cant find it.
Old 23rd September 2003, 06:11 AM   #2
wrl is offline wrl  United States
Search for momentary switch.
Anything worth doing is worth doing right... and redoing to make it better... and again to fix it back the way it was.
Old 23rd September 2003, 06:43 AM   #3
Banned
What about the value of this part that is not identified?
what transistor should i use. ?
Old 23rd September 2003, 06:52 AM   #4
JOE DIRTŪ is offline JOE DIRTŪ  Canada
JOE DIRTŪ's Avatar
any small signal transistor such as a 2n4401 will do....basically the relay coil impedance determines the size (current capability)
Old 23rd September 2003, 09:37 AM   #5
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
Tell us what your relay coil's resistance will likely be...from there we can calculate the current draw and the transistor that best fits the job...I guess a TIP31 there will do for any relay..except for those REALLY BIG relays...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Power On.Hide this!Advertise here!
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 07:38 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
