I have a rather newbish question for you guys and I hope I can get some info on I/V stages. I have seen the reference to an I/V stage at DAC outputs and in pre-amps (after a volume control). What does that stage do exactly? I got something like, it converts current to voltage, but I am not quite clear on how or why and how does it function. Can anyone explain a bit on the I/V stage and some design principles and where it is applied? I have seen implementations with transistors and op-amps. Maybe a good schematic pic with an explanation of what the signal does would be really helpful. Thank you!
This is not reality... |
#2 |
Many DACs have current output - see, for example, the datasheet for PCM1794A. These DACs require a very low (ideally zero) impedance load, and will supply current on the order of a few mA peak-to-peak into that load. The important part is that the voltage drop on that load must be small in order for the DAC to meet its specifications.
Your normal amplifier has voltage input with reasonably high impedance (say 10 to 100kOhm) and require reasonably high voltage (say 100mV to 2V) to operate. An I/V converter provides low impedance load for the DAC and converts the DAC's output current into voltage for the following stages. The simplest converter is a resistor, and there are designs that use just that. An example is ezDAC (search the thread for the schematic; the original developer's website doesn't seem to be working anymore). However, the DAC's output current flowing through a resistor produces an unwanted voltage drop. A more popular converter is an inverting opamp, which has virtual ground at its inverting input. A DAC's output is connected directly to that virtual ground, the DAC's output current flows through the opamp's feedback resistor, and the opamp works to maintain the virtual ground by providing a voltage swing at the output. An example schematic can be found in the above referenced datasheet for PCM1794A. There are other designs, such as Zen I/V. Last edited by alexcp; 7th February 2012 at 03:46 AM. |
#3 | |
Alex thanks a lot for the explanation! This really helps! The links are most helpful too!
I have been looking at the PCM1794 DAC for my future project. It looks like it is a really good DAC and it's used in some high end stuff. I guess it is all in the datasheet once again hehe. But I do have one more question regarding the following form the PCM1794 page. Quote:
Thanks, Ivan
#4 | |
Normally DAC manufacturers also show an evaluation circuit that should work well (look out for the docs of an eval board if necessary). In this case the datasheet doesn't go into much detail, but there's an eval board named DEM-PCM1794 for which a detailed schematic is provided. On the eval board they're even using a less-than-unity gain amp after the I/V to get 2 Vrms. |
#5 |
On the PCM1794 datasheet, see Figure 24 for TI's recommended output stage. The LT1028 at the output could probably be whatever opamp you liked.
#6 |
The one and only
Here's a cheap tweak. Try using the circuit in the app notes but also load
the current outputs of the DAC with resistance to ground. Pick a value that cuts into the output signal slightly.
#7 | |||
tnx guys
#8 | |
Digi Scoop 1 you will find the appropriate instructions concerning the resistor value BTW - by post #38 about TDA-1541A s1 vs modern DAC? I've compiled various threads from this forum concerning IU resp. IV converter topologies. Last edited by tiefbassuebertr; 8th February 2012 at 05:50 PM. |
#9 | |
Idk why but it seems to me that some people really don't like the op-amp I/V stage... power supply noise? Hard to find a good opamp?
#10 |
In Zen I/V article referenced above, Nelson Pass briefly discusses why opamps may be out of their element when it comes to I/V conversion. A quote:
Without wanting to get into an argument about the pros and cons of op amps in audio circuits, I must point out that this sort of usage of an op amp places it at the greatest possible disadvantage – operation at unity gain with a mix of audio and high frequency noise.However, I cannot remember one current output DAC datasheet which would recommend anything else but an opamp I/V to obtain the specified performance. Last edited by alexcp; 9th February 2012 at 06:06 PM. |
| Mixer Section explanation help needed. | graygem | Analog Line Level | 1 | 12th May 2011 04:56 PM |
| QTS/OB explanation needed | InclinedPlane | Full Range | 36 | 19th May 2010 04:30 AM |
| AC power connection schematic explanation needed | Peter Daniel | Pass Labs | 20 | 31st July 2007 04:16 PM |
| D1 Output Stage Help needed. | pro | Digital Source | 18 | 30th June 2004 08:06 PM |
| Current Mirror Explanation Needed. | vdi_nenna | Everything Else | 2 | 27th May 2001 12:23 PM |
| Page generated in 0.15090 seconds (77.98% PHP - 22.02% MySQL) with 10 queries |
