Old 22nd September 2003, 07:08 PM   #1
sam9 is offline sam9  United States
sam9's Avatar
Default MOSFET Output Pair Suggestions ??
I've made a couple of small BJT amps in the low power range (15V-30V) and I thinking about doing something similar using MOSFETs in a SF configuration. Physical size is a factor so I'm looking for a TO-220 package. Scanning the usual catalogs (DMgikey, Mouser, etc) it is hard to figure out what would constitute a complimentary pair.
Any suggestions in this regard? Naturally it would be nice if they were readily available.
Old 22nd September 2003, 07:17 PM   #2
PMA is offline PMA  Europe
PMA's Avatar
IRF540/9540
Old 22nd September 2003, 07:53 PM   #3
DrG is offline DrG  South Africa
In your specified voltage range IRF510 / IRF9510 would probably suffice.
Old 22nd September 2003, 09:08 PM   #4
Account Disabled
I would 2nd PMA's suggestion.
My experience with those mosfets tho. is that they are not very stable in anything other than an EF-equivalent set-up.
Other than that, those are great output devices, impossible to blow-up, .
BTW, those aren't complimentory pairs. The Hitachi pair is but they are expensive.
Old 23rd September 2003, 12:17 AM   #5
blmn is offline blmn  Brazil
blmn's Avatar
As millwood said, they are not complimentary. For example, different gate capacitances must be considered during the design.
regards
Old 23rd September 2003, 01:07 AM   #6
sam9's Avatar
Thanks for the input. I found SPICE models at the DuncanAmp website, so I will be working with those for a while. At least then I will have some idea what the likelyhood of getting ssomething satisfactory will be.
Is the Toshiba 2SJ201/2SK1530 pair (Mosfet) suitable for output stage ? Johnix Solid State 23 4th August 2012 02:32 PM
Tube/MOSFET hybrid results/comments/suggestions? lgo51 Pass Labs 59 22nd June 2008 04:02 PM
DAC output mods - suggestions please. Pulse-R Digital Source 11 22nd February 2008 10:39 AM
AMPLIFIER SCHEMATIC USING OP AMP AND PAIR OF MOSFET's please zox2003 Solid State 12 16th March 2005 10:35 AM
suggestions required on mosfet matching setup for aleph x pamaz Pass Labs 4 20th February 2004 12:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
