The Rush cascode has some adherents but it carries the disadvantage of dc-offset compared with an LTP input.
Replacing one device with a depletion mode FET, or JFET, or Triode, you can remove the dc-offset quite conveniently. It seems to me that triodes are just as easy to find as JFETs these days. The harmonic profile is also rather nice. The 6N23P is a tube you can use at low voltage & low current, it has good transconductance and compared with most tubes it has a very modest heater requirements (6.3V at 300mA = $5 transformer) plus you can use the popular ECC88 or 6DJ8 instead.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. Last edited by Bigun; 4th February 2012 at 06:53 PM. |
#2 |
Nice circuit, Gareth. Good profile, elegant avoidance of offset problems.
OTOH, a bit of offset at the input polarises the cap, makes it sound better.... Hugh |
| Rush Cascode Headphone Amp + JLH Output Stage | keantoken | Headphone Systems | 435 | 18th June 2011 06:56 PM |
| Rush Cascode inputstage on JLH 10W | revintage | Solid State | 12 | 31st January 2010 09:16 PM |
| Transconductance amplifier based on hybrid cascode | ErikdeBest | Tubes / Valves | 9 | 15th November 2009 10:51 PM |
| The Rush Cascode: Possible Wiki page | keantoken | Solid State | 0 | 28th January 2009 10:59 PM |
| Hybrid Cascode ? | Eli Duttman | Tubes / Valves | 3 | 9th May 2006 11:35 PM |
| Page generated in 0.07321 seconds (68.46% PHP - 31.54% MySQL) with 11 queries |
