Parasound HCA-3500 Bias issue
Old 9th February 2012, 03:37 PM   #11
john curl is offline john curl  United States
john curl's Avatar
NO, I do NOT do repairs. Please live with it, or send it to Parasound.
"Condemnation without Examination is Prejudice"
Old 10th February 2012, 02:17 AM   #12
thejck is offline thejck
no i mean. can anyone get me a repair manual so that I could service it myself?
Old 10th February 2012, 04:19 AM   #13
john curl's Avatar
Can you, jck, do it without screwing it up? If you can do it, and TRUST your capabilities, then get two medium size clip leads. Attach one end of each to a multimeter that can measure milliVolts. When you open the case, find ONE convenient EMITTER RESISTOR to put the opposite clip lead ends, across the resistor. Now you are in a position to measure .015-.025 Volts.
Attach clip leads BEFORE turning on the amp. Wait at least 1/2 hour before determining the final quiescent current as determined by the voltage drop across the EMITTER RESISTOR.
IF the voltage drop, over time is NOT in the range of .015-.025 Volts, then find the trim pot that adjusts the measurement. You have to look for it. BE VERY CAREFUL NOT TO TURN THE POT TOO MUCH, until you get a feel for its range.
That should do it, but BE CAREFUL!
Old 10th February 2012, 10:43 PM   #14
thank you
Old 12th February 2012, 08:08 PM   #15
john curl's Avatar
Good luck, jck. I hope things work out, but I can't promise. You should use an ISOLATED screwdriver, (you can make one, yourself with some tape wrapped around the shaft), to protect you from bumping the wrong component. Usually there are 2 pots in series, why I do not know.
Old 1st March 2012, 03:59 AM   #16
bigskyaudio is offline bigskyaudio  United States
bigskyaudio's Avatar
Like John says, do use an insulated driver and don't press too hard as the pots are somewhat fragile. He is also correct in stating that there are 2 pots in series. Adjust TVR1 which is the idle bias adjust and set it for 4mV(+/-1mV) DC on your voltmeter with the leads across one of the .22 ohm emitter resistors. I would let the amp idle for at least 30 minutes before doing this. The HCA-3500 amplifier also has a dynamic bias adjust and you set TVR3 to 18mV(+/-2mV) DC while applying an audio signal (music will do). After removal of the audio signal, it will take a couple of minutes for the bias to drop back down to idle. I have seen a number of HCA-3500s with the dynamic bias around 40-50mV and the heatsinks are quite hot.
Parasound HCA-3500 Bias issueHide this!Advertise here!
Parasound HCA-3500 Modifications / Upgrades dcmartinpc Solid State 3 27th April 2015 03:43 PM
parasound HCA-1206 (Tony at Parasound.com) ostie01 Solid State 1 10th July 2012 05:24 AM
Parasound HCA-1000a Bias Circuit Correct?? birdyman Solid State 17 4th January 2012 09:31 PM
Help modifying HCA-3500 ironhardware Solid State 14 11th December 2008 11:38 PM
Parasound HCA-3500 USA to UK power supply Abe Solid State 4 29th November 2004 06:56 AM
