Ok started a new thread because the other one was soo old. Ok here's my problem. Just picked up this amp. brought it home and found this. Channel A seems to be perfect. But channel B seems have a issue. When a relatively low signal is applied the channel sounds ok. but as more signal is applied the clipping light comes on relatively quick and starts to sound rough around the edges. With even more signal applied the amp goes into protect. as soon as the drive is reduced the amp comes out of protect and continues to play.
whats going on?
It isn't fun unless it can kill you! |
#2 |
Do you have a scope?
Been years since I owned a Crest VS900 power amp. You need to look at the front end of the amplifier. I believe there is a 5532 op amp in the front end. That is where I would start. I believe that when I took a good hard look at the one I had my supply feeding the op amp had a problem that I corrected and it worked fine after that. |
#3 |
Ok thanks. I have to see if my scope still works. I took a break form the audio relm for awhile.
#4 |
any Schema?
#5 |
Send me your e-mail address and I will send the schematics.
Candidates for the Darwin Award should not read this author. |
#6 |
Scope is broke. I'm just going to replace the sk chip and see what happens..
#7 |
| Crest VS 900 problems | Original Burnedfingers | Solid State | 4 | 5th February 2012 07:41 AM |
| Empire 900? | Zen Mod | Analogue Source | 0 | 2nd July 2005 11:06 PM |
| HH 900 amplifier | Attie | Solid State | 2 | 30th June 2005 06:04 PM |
| 900% Vas tolerance? | Otter | Subwoofers | 1 | 10th May 2005 12:16 AM |
| Page generated in 0.07490 seconds (76.84% PHP - 23.16% MySQL) with 10 queries |
