Delayed on-fast off board
Old 31st January 2012, 04:28 PM   #1
Neutrality is offline Neutrality  Denmark
Default Delayed on-fast off board
Board for delayed on-fast off. Intended for use in a headamp I'm working on.
Board is not completely done yet. Might do a few changes to the layout but nothing major. Mainly tidying up the silkscreen, adding text on inputs/outputs. Also, T2 and T3 are supposed to be TO-92 FETs, 2N7000, but as I'm not home at the moment I dont have access to the right FET models. Taking their place are 2 x EBC TO-92 BJT's. Pinout corresponds to the 2N7000 FET's(E=S, B=G, C=D). Will be fixed in the weekend when I get home.
Runs on +12V DC.
Has a 3 second delay before activating the relay and an AC sensor circuit to turn off the relay immediately when the supply is powered down.
Based on ideas taken form DIYA and various other sources on the net.
Old 31st January 2012, 06:34 PM   #2
Getting close to done.
Only thing left is replacing the BJT's with the correct FET's.
Removed the ON LED, served no real purpose.
Also changed the way the signal goes through the relay. Now in OFF state, output to the headphone will be grounded instead of floating.
Delayed on-fast off boardHide this!Advertise here!
ta2020 anti "pop noise" relay - really needed? yakideo Class D 5 18th July 2011 03:28 AM
Active Filter, Delay, and LT circuit board CharlieLaub Analog Line Level 16 14th April 2011 12:23 AM
Time delay start board for tube amps gjo Tubes / Valves 4 26th November 2008 03:23 AM
Fast GB: LM4702 high power amp test board ;) veteran Group Buys 150 12th March 2007 04:30 PM
Copyright ©1999-2017 diyAudio
