Old 23rd September 2003, 10:09 PM   #21
SY's Avatar
Dumb question- the 797's diff input is cascoded, current mirrored, and bootstrapped six ways from Thursday. Is that possibly the reason for the low bias current?
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 23rd September 2003, 10:24 PM   #22
diyAudio Retiree
Smile No..... and it is a fairly simple topology BION
The simplified schematic shows a diff pair with a folded cascode and a current mirror load. This is followed by two stages of emitter followers. This is simple schematic showing only the basic outline of the signal path. But as op amps go this is a pretty simple topology and not near as convoluted as many I have looked at.
Bias compensation:
http://www.analog.com/library/analog...versary/6.html
Someone will read it eventually I suppose..
Old 24th September 2003, 05:35 AM   #23
jcarr is offline jcarr  United States
Hi Sy:
>the 797's diff input is cascoded, current mirrored, and bootstrapped six ways from Thursday. Is that possibly the reason for the low bias current?<
The cascode part of the 797 is of the inverted/folded type, which is good for stability and bandwidth, but AFAIK, means little for the base or bias currents of the input diff pair. The second-stage current mirror just sums the plus and minus portions of the signal into a pushpull output, with probably very little effect on the input base or bias currents.
Finally, the major bootstrap mechanism in the AD797 maintains a constant voltage across the summing current mirror, which will kick up the OL gain a lot, and I think will also help the PSRR on the minus voltage rail. But again, I doubt if this represents any direct advantage for input base or bias currents.
Of course, there is always the possibility that the real AD797 circuit is far more intricate than what Analog Devices chose to publish.
best, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 24th September 2003, 07:12 AM   #24
PMA is offline PMA  Europe
PMA's Avatar
Ohayo gozaimas Jonathan,
ogenki desuka?
I have visited your www and there is a greeting in czech language. Does your company have activities in the Czech republic?
Pavel
Old 24th September 2003, 08:03 AM   #25
Pavel: My some-times engineering design partner, Petr Mares, is originally from Czech, and he is also the person who designed and programmed most of the Connoisseur website.
We haven't done anything in the Czech Republic yet, but who knows what the future may bring?
regards, jonathan carr
Old 25th September 2003, 04:07 PM   #26
diyAudio Retiree
"Of course, there is always the possibility that the real AD797 circuit is far more intricate than what Analog Devices chose to publish."
That is why it says simple schematic on the drawing from the data sheet. I feel quite sure this is nowhere near the actual circuit and would image that the bias compensation network is one of the bits not shown. Op amps are very proprietary. The reason Spice models are grossly simplified macromodels is for both the protection of the design and lengthy simulation time for a model that represented the real complexity of the design.
http://www.linear.com/pub/document.h...pp&document=51
Old 25th September 2003, 05:24 PM   #27
andy_c is offline andy_c  United States
Banned
Originally posted by Fred Dieckmann
(...)The reason Spice models are grossly simplified macromodels is for both the protection of the design and lengthy simulation time for a model that represented the real complexity of the design.
This is a bit off-topic, but to add to what Fred has mentioned, some of the SPICE op-amp models are really poor. In LTSpice for example, all of the Linear Technology op-amp models have the property that the simulated supply current does not change as a function of the output current delivered! I believe this is a property of the Boyle model. The Analog Devices op-amp models are much better. There's an application note describing them here:
http://www.analog.com/UploadedFiles/...01016AN138.pdf
If I ever need an op-amp model for SPICE, I try to grab the Analog Devices model if I can find one.
Old 26th September 2003, 12:12 AM   #28
diyAudio Senior Member
fdegrove's Avatar
Exactly.
Frank
Old 26th September 2003, 12:26 AM   #29
SY's Avatar
Default 797
AD confirms that there is bias compensation circuitry on the chip.
Old 26th September 2003, 05:40 AM   #30
Thank you for the clarification, SY.
general question about feedback, input impedance, and noise nobody special Solid State 8 29th August 2005 10:23 PM
current bias j-fet input 2sk170 ,2sj74 at input stage YUTK Solid State 11 2nd June 2005 04:34 AM
How can I calculate input noise voltage and current? thanh Solid State 0 8th July 2004 05:34 AM
Page generated in 0.13476 seconds (80.53% PHP - 19.47% MySQL) with 11 queries
