Old 30th January 2012, 05:15 AM   #1
Default Matching at idle current
Hi.
I have a question. Why do many folks suggest matching at the amplifier's quiescent current. Doesn't the amount of current through parallel connected transistors vary with a load and signal?
Or am I understanding this the wrong way. Does matching at quiescent current, ensure linear, equal sharing throughout, regardless of load and signal level??
Old 30th January 2012, 07:08 PM   #2
look at the Vbe vs Ic of a BJT.
Now look at a parallel pair of output BJTs.
For simplicity assume the base currents are the same.
What is the Vbe difference between the two output devices?
If one output device is selected randomly from the box and when connected up, it passes 1A of quiescent current and the other BJT passes 500mA of quiescent current from the same Vbe, then consider the operating temperature Tj of the two BJTs? Which one runs hotter?
Go back and look at the temperature effect on the Vbe vs Ic graph. Will the warmed up devices still be passing 500mA and 1000mA.
regards Andrew T.
Old 31st January 2012, 11:51 AM   #3
Thanx Andrew!
Point well made!
Audionet AMP 1 idle current chris86 Solid State 6 20th December 2011 09:13 PM
help setting up idle current lensmanMk2 Solid State 31 10th March 2010 11:48 PM
Idle current adjustment for NAD gvelim Solid State 0 5th August 2008 03:56 AM
XM-1502SX Idle Current sdoom Solid State 1 9th July 2004 07:35 AM
SMPS Idle Current cm961 Parts 2 20th February 2004 05:56 AM
Page generated in 0.08224 seconds (61.14% PHP - 38.86% MySQL) with 10 queries
