Old 3rd February 2012, 07:08 PM   #11
Hi all,
Oops ! I forgot to ground the heatsinks !!!
Today, I connected the heatsinks to ground and everything works fine !
Thanks for everyone who gave me ideas.
I still have one issue: Low frequency "Hum" is audible when I set the volume to higher side. (Probably, mains frequency???) Any ideas to adoid this?
Raj.
Old 4th February 2012, 12:12 AM   #12
See whether it's still there with the inputs shorted.
I never noticed this thing only has a specified damping factor of 20 at 8 ohms (0.4 ohms R_out). Funny little amp.
Old 4th February 2012, 03:12 AM   #13
gootee is offline gootee  United States
Originally Posted by svkr2k View Post
Hi all,
Raj.
See if the hum is still there with nothing connected to the inputs.
If not, then it could be that the input signal/gnd pairs have too much enclosed loop area. And it could also be that some conductor pair with mains frequency has too much enclosed loop area.
Old 4th February 2012, 06:34 AM   #14
Hi sgrossklass,
I couldnt understand what you mentioned on damping factor, could you please explain. Thanks a lot !
All,
I believe I should mention this ... I replaced all electrolytics with common grade (probably industrial) and not "audio grade" capacitors. Is this okay? Or how will this affect the performance of the amp?
Thanks !!!
Raj.
Old 4th February 2012, 03:03 PM   #15
The electrolytic caps will probably be fine. I would worry more about the matching of the transistors you replaced.
Did you try testing for hum with the inputs open (not connected) and with the inputs shorted, as we asked?
BOSOZ Output Waveform Question hifimaker Pass Labs 8 9th April 2007 01:34 AM
Matisse Fantasy waveform output test ckwong99 Tubes / Valves 35 11th January 2007 01:03 PM
SMPS output waveform discontinuities b-ohica Power Supplies 2 29th November 2006 01:24 PM
How to test for oscillations? Jye Chip Amps 13 20th October 2004 11:56 PM
amplifier oscillations lowfi Pass Labs 33 29th May 2002 07:32 PM
Page generated in 0.07609 seconds (74.06% PHP - 25.94% MySQL) with 10 queries
