Old 29th January 2012, 09:05 PM   #11
The board is pressed fiberglass and yes traces of the fluid will seap into the board at some point. You will not see bluging in these cap like the bad caps in computer mb's. Some times the board wil have to be cleaned down to the copper traces. After the board is compleated get some conofrmal coaating from Mouser, like 30+ a can do not use clear spray paint, it's not the same. Just make sure when you order the caps from mouser you look at the size of the caps to make sure they will fit. The only adjustments are the BIAS and unless your friend has done a lot of 565's it can easly be done wrong. Even the manual leaves out step's on this adjustment. The unit also should be qualified by distorshion test SIAND and DIST using a HP8903A and scope or equiv. There is no way I could advice you on parts replacement other then the lytic's without testing the unit myself. Goodluck.
Ed
Old 1st March 2012, 05:55 AM   #12
Before cleaning, remove the bias pots and metal brackets. I use Simple Green cleaner diluted about 1 part to 10 parts RO water. Let the boards soak in a plastic tray for about 15 minutes and scrub with a soft nylon acid brush. Rinse well and repeat; the board has to be totally free of electrolyte contamination and it may take several cleaning cycles. I use a hair dryer on low to dry the boards and then let them air dry for at least a day. The capacitor electrolyte is colorless and very difficult to see without a magnifying lamp. The three 220uF electrolytics (per board) are the problem and the leaky cap issue applies to the GFA-585 and the GFA-565 monoblocks. Be sure to remove the DC servo IC and clean the chip itself, especially underneath and between the pins. While you are at it, replace the two 100uF bypass capacitors.
Speakers for Adcom GFA 585? Ed Holland Solid State 103 5th July 2012 11:59 AM
ADCOM GFA-585 LE amadork9 Solid State 1 18th January 2011 03:09 PM
GFA-585 Repairs Teeboyd Solid State 0 14th March 2010 06:36 AM
Adcom GFA-585 HELP NEEDED! georgehifi Solid State 19 18th October 2003 02:33 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
