Old 27th January 2012, 10:28 PM   #1
tojoko is offline tojoko  Netherlands
Default No sound Marantz MA6100
I use 8 Marantz MA6100 as amps for an active loudspeaker setup, 1 has the problem, the relais seems to work, but no sound, when power off, one relais (near the front)clicks straight away, another (at the rear) clicks about 3 seconds later, can it be a relaisproblem, if so where can i get the Omron P5GA-28 24 volt (when i read it correctly)relais?
Old 28th January 2012, 12:33 AM   #2
agdr is offline agdr  United States
agdr's Avatar
Here is the schematic and parts list
Marantz MA6100 schematic
It shows that relay is a G5PA-28.
Old 28th January 2012, 09:32 AM   #3
Default Omron G5PA-28-24V
Hi
Thanks, I looked around, seems hard to get this part, do you know a similar part I could use to replace this relay,
thanks for any help....
Old 28th January 2012, 11:16 AM   #4
Default no sound Marantz MA6100
Hi
I found a working relay,fitted it, the relay works, but there is no sound at all coming from it, what can be wrong?
Tojoko.
Old 28th January 2012, 11:33 AM   #5
Its not the relay.
Its probably bad caps in the signal path. The MA500 suffers from low to no output simply because the caps need changing.
Old 28th January 2012, 12:19 PM   #6
Default Finally sound!
Hi
Thanks for the reply, I already changed all the suspected caps, that was not the problem, the output terminal is bad, i use banana plugs and the minus terminal did not connect to the board....now i put in with screw all is well, relay was broken though, I replaced it with an old DEC DH2TU 24 volt relay, just used the backpins, there is no problem fitting these, the holes are already on the board.
Tojoko.
Old 28th January 2012, 12:21 PM   #7
Have tried to download this file without success. Can someone send it to me?
Old 28th January 2012, 12:22 PM   #8
The output terminal are a common problem with ALL the newer Marantz products. Glad to hear you got it.
Old 28th January 2012, 12:33 PM   #9
agdr's Avatar
PM me your email and I can send you the pdf as an attachment.
Marantz PM-40SE No sound. Filding Solid State 15 14th January 2012 05:35 PM
McIntosh MA6100 antiquekid3 Solid State 8 3rd June 2010 01:21 AM
no FM sound on marantz 2245 llib Analogue Source 2 27th November 2005 02:22 AM
McIntosh MA6100 Hornboy Solid State 6 9th November 2005 07:42 AM
Marantz MA6100 monoblocks griff Solid State 2 15th February 2002 07:52 AM
Page generated in 0.10430 seconds (75.92% PHP - 24.08% MySQL) with 10 queries
