I'm looking for a new amp project that can use an existing chassis and power supply. The amp in question is a dead Adcom GFA-555 which has some nice heat sinks and about 60,000uf of power supply capacitance. The problem is that is has 81V rails (PS schematic attached), which exceeds most of the projects I've seen here. The power supply has tested well, and seems to be capable of reuse.
I've found the thread Plh Retrofit to Hafler/Adcom that specifically mentions re-using an Adcom GFA-555 but it seems to have petered out. I'd like to try an F5 amp (from the Pass Labs forum) but my high rail voltage seems inappropriate for it. I'm hoping for a project that has a good cost/performance ratio as my SE 300B project is consuming most of my hobby funds. At the very least I want something that sounds as good pr better than a stock GFA-555, however. Please suggest applicable projects and/or workarounds for my high rail voltage. Thanks! p.s. The completed project will be hooked up to a pair of stock Tri-Trix speakers (nominally 8 ohms) in a large-ish basement. Bass is handled by a dedicated sub-woofer. Fairly low volume levels are acceptable. Primary music will be rock with some techno and solo-female-vocalists. |
#2 |
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
There is an chip amplifier capable of more than 100W called "STK4044" series, but at 71V, and are easy of build. Try some more voltage IC.
A veces pongo un circo y me crecen los enanos... "Que se llama soledad", Joaquin Sabina, el capo. |
#3 |
Just thinking aloud without really thinking
You're on 120V ? Amp can be used on 240V and looks to have a good selection of tappings. So wire the tranny for 220 or 240 and that will give correspondingly lower output voltage.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#4 |
Both excellent advice!
I see that Digi-Key still has the LM4702 in stock. I'll see if I can find any listening impressions with that chip. Mooly, will wiring for 240V input give me 1/2 output (120 to 81 vs 240 to 40.5) or is there a conversion factor? Thanks!!! |
#5 |
Banned
That is correct, 40.5v.
The ratio is 0.68V "out" for every volt "in" |
#6 |
No conversion factor... it's as GloBug says.
#7 |
I would assume at half the power, i.e. the same secondary ampere, dictated by the thicknes of the wire ?
Best regards Ebbe |
#8 |
Banned
I would assume too, but did not state it as I was not sure.
#9 | |
#10 |
The 81V rails are good for about 400W into 8ohms. This would be quite a project.
Something like this perhaps? Trouble is, it 'only' uses 70V rails. Last edited by ingenieus; 31st January 2012 at 10:59 AM. |
| Seeking help for first Speaker project | Ale79 | Full Range | 29 | 2nd January 2012 07:17 PM |
| Seeking comments on Borbely DC-100 project | Tubenstein | Solid State | 12 | 30th November 2011 12:01 AM |
| Seeking comments on a 3 way dipole project | joe carrow | Multi-Way | 25 | 2nd October 2004 12:10 PM |
| Seeking advice for my TT project | Dumbass | Analogue Source | 1 | 7th September 2003 07:31 PM |
| Page generated in 0.11238 seconds (76.69% PHP - 23.31% MySQL) with 11 queries |
