Old 25th January 2012, 11:27 AM   #1
Default Problem with my Musical Fidelity A1-X
Good evening to all,
a few months ago I sold my Musical Fidelity X-A1 that I bought used a few months before ... the person I sold it a few days later told me that my youth sells at some point the music has ceased to be reproduced and the amp started to fry. Of course I have given back money to the buyer and I did return the amp.
Now if you turn on it, and there is nothing plugged in, makes a sound like frying and feels (I opened the lid) it stinks
Someone would know what could be the problem...
Davide
P.S. it may serve you I'm ready to take pictures ...
Old 25th January 2012, 11:33 AM   #2
oiphy is offline oiphy  Norway
diy newbie
oiphy's Avatar
you should really post pics. doubt if anyone can help you without pics for a start.
regards
" If you're going throu hell, keep going"
Old 25th January 2012, 12:23 PM   #4
Here some pictures... I have to find my camera for dome better pic.
ImageShack® - Online Photo and Video Hosting
Old 25th January 2012, 01:08 PM   #5
KatieandDad's Avatar
From your photos it's pretty obvious that the four diodes arrowed have bitten the dust.
In such an old amp, the question has to be how much other damage is there ?
MF amps are prone to cooking.
I would start by replacing all the big capacitors, all the rectifier diodes and then check the output transistors.
Old 25th January 2012, 01:15 PM   #6
diy newbie
oiphy's Avatar
I must agree with katieanddad.
Old 25th January 2012, 01:25 PM   #7
GloBug is offline GloBug  Canada
Banned
That amp does not appear that "old", at least to me. If it is a problem design, I would stick a gainclone in that chassis.
Old 25th January 2012, 01:29 PM   #8
I've certainly repaired amps by substituting amplifier modules for blown amps.
This does nothing to preserve the original character of the amp though if you are trying to restore one.
Sometimes your substitution could be better than the original. MF do have their own following though and are highly regarded amongst that fraternity.
Old 25th January 2012, 01:32 PM   #9
diy newbie
oiphy's Avatar
had a few mf amps myself and they are good as hell When agreing with katieanddad i was refering to the repair. MFamp never get old
Old 25th January 2012, 01:36 PM   #10
Some amps are timeless and MF certainly look modern.
However, most MF amps are quite small and the electolytic capacitors age (or are cooked) .
In this case I would suspect that the caps have dried out causing the diodes to fail.
I would check the output transistors though just in case something else has caused the diodes to blow.
Schematic for Musical fidelity X-A1 stormsonic Solid State 0 26th October 2010 06:43 PM
Musical Fidelity A1 bias tubeing Solid State 7 24th June 2010 11:29 AM
Musical Fidelity A1 Improvements juluska Solid State 17 8th February 2010 12:37 PM
Musical Fidelity A1 modification ilimzn Solid State 5 19th January 2007 12:34 AM
Musical Fidelity A1 Heatsink Assesears Everything Else 5 17th February 2004 07:45 AM
Page generated in 0.11507 seconds (78.59% PHP - 21.41% MySQL) with 11 queries
