Wanted->Discrete balanced to unbalanced CMR converter
Old 21st September 2003, 03:32 AM   #21
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally posted by Brian Guralnick
Well, I prety much gave up. I guess I will use a transformer.
'Bout time you came to your senses.
Q1: Which companies make these high performance line matching transformers?
Jensen, Sowter, Lundahl, and Stevens & Billington to name a few.
Q2: With a transformer, should I buffer the output?
Not necessarily. The output will see pretty much the same impedance it'd see otherwise.
Q3: Using a transformer would make life extra easy for integration into the Balanced Zen Pre-amp. However, I do not need the signal gain, would a simple voltage follower buffer make things any better?
How do you mean? A voltage follower buffer where? In lieu of the Zen?
Q4: Are there any worthy pre-amp output buffer stages which can drive headphones?
Sure. Take a look at some of the projects over at Headwize.
se
Wanted->Discrete balanced to unbalanced CMR converterHide this!Advertise here!
unbalanced to balanced converter lumanauw Pass Labs 53 2nd June 2011 05:08 AM
Balanced To Unbalanced Audio Converter SprockeT1597 Parts 3 7th February 2009 04:03 AM
Unbalanced - Balanced Tube Preamplifier wanted bebong Tubes / Valves 9 21st June 2004 05:32 AM
unbalanced to balanced converter Salsero Solid State 27 21st September 2003 09:12 AM
unbalanced/balanced/unbalanced conversion using transformers vladimir Solid State 10 27th February 2003 06:54 PM
