Old 23rd January 2012, 11:53 PM   #1
Default Mosfet Transistor question
I have two dead transistors IRFP9240 and IRF9610. I tested them and I am not getting any reading from them. Can I just replace them with new or do I have to replace all of them?
Old 24th January 2012, 12:00 AM   #2
nigelwright7557's Avatar
You wont get a reading from them unless they are dead.
They usually go short from D-S and sometimes gate to D or S.
Test them all for shorts.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 24th January 2012, 12:03 AM   #3
All of them but those two I am getting readings. I checked and rechecked just to make sure. It is my fault too. I recapped the amp and had two wires switches. Left channel works fine and the right blows fuses. I have been checking the values to everything on the board.
Old 24th January 2012, 12:08 AM   #4
A lot depends on what damage the swapped wires caused.
Sometimes just replacing damaged mosfets works and other times they just blow again if you havent fixed all the faults on previous stages.
If it is blowing fuses then it sounds like blown mosfets. The only other thing capable of blowing fuses is a power supply fault.
Old 24th January 2012, 12:11 AM   #5
The power supply is good as the other channel is working fine. I did some reading and you confirmed it that a dead mosfet will cause the fuses to blow.
Now, can I just order one of each or is it a good idea to replace all of them?
Old 24th January 2012, 12:14 AM   #6
I would just replace the dead ones. So long as the others dont have shorts they should be ok.
Old 24th January 2012, 12:16 AM   #7
Thanks for your assistance. I'm a novice, but learning real fast and I find it very interesting. I recapped my rotel pre and wow it sounds so much better.
Old 24th January 2012, 12:18 AM   #8
Thats what I will do. Thanks again.
Old 24th January 2012, 12:25 AM   #9
It should fix it.
I usually find blown mosfets are all that is wrong.
I dont want to get too technical but sometimes something else can be taken out to further back in the circuit with the mosfets
If i replace the mosfets and they blow again I take out all the mosfets and wire the VAS output back into the ltp and this closes the loop for testing the amplifier. I can then check for dc bias and offset.
Old 24th January 2012, 08:26 AM   #10
I wouldn't just replace those ones that are fried. They need to be matched- all of them. If you replace only the ones that are fried with diff production date ones, chances are that you will be sacrificing reliability. Also from experience, always desolder Mosfets when testing. For some reason they can test no-short when in circuit. Maybe someone can tell me why?
Help me find a Mosfet/Transistor amp project useing what I have available?? Minion Solid State 11 9th May 2007 04:30 AM
Transistor and MOSFET recommendations? meretrix Parts 2 24th January 2005 11:45 AM
Audio MOSFET transistor Hisatugo Solid State 2 11th August 2003 08:41 AM
Transistor / MOSFET Questions... Solid Snake Solid State 4 27th February 2003 08:05 PM
Is this MOSFET transistor? Mikka Solid State 5 3rd February 2003 07:07 AM
Page generated in 0.09049 seconds (84.43% PHP - 15.57% MySQL) with 11 queries
