#11 |
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Check also all drivers. Some times all drivers are catastrophically destroyed when the power mosfet gets shortcicuited from drain to gate, more in case of high drain voltages. Is case of routine at my job repairing speed drives for AC motors.
A veces pongo un circo y me crecen los enanos... "Que se llama soledad", Joaquin Sabina, el capo. |
#12 |
Use a bulb tester to work safely on it and save blowing transistors.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#13 |
Im going to desolder them tonight and test. It sounds like a good place to start and I will probably order 8 new mosfets tonight. I ordered 2 yesterday, but was wondering about the matched issue. Im glad someone mentioned it. In the least, I will have two spares. Unfortunatly it takes forever to ship from china.
#14 |
I replaced the suspected transistor, set the bias and the amp fired up. It does run hotter than normal, but sounds fine. I think I understand why they have to be replaced in series now. I think I am going to buy 12 matched from ebay. What is the tolorance to make them "matched"? Is 50mv alright?
#15 |
Do they need to be matched ?
The bias (quiescent current in FET's) will determine how hot it runs. Have you followed a specific manufacturer procedure to reset it. Is the bias stable with temperature ? Have you rechecked and reset the bias when the amp is really hot ?
#16 |
I think it's mostly unnecessary to match all transistors.
My advice: Make sure that the complementary types are from the same manufacturer.
Regards http://xipix.de/ |
#17 |
Replace all of them. Make sure the batch numbers on them match!! If the unit has source resistors, make sure they are matched too. Once everything is soldered in. measure across source resistors. They should all give the same voltage reading. If they are not, move mosfets around a bit to mix 'n match!!
| Help me find a Mosfet/Transistor amp project useing what I have available?? | Minion | Solid State | 11 | 9th May 2007 04:30 AM |
| Transistor and MOSFET recommendations? | meretrix | Parts | 2 | 24th January 2005 11:45 AM |
| Audio MOSFET transistor | Hisatugo | Solid State | 2 | 11th August 2003 08:41 AM |
| Transistor / MOSFET Questions... | Solid Snake | Solid State | 4 | 27th February 2003 08:05 PM |
| Is this MOSFET transistor? | Mikka | Solid State | 5 | 3rd February 2003 07:07 AM |
| Page generated in 0.10017 seconds (68.89% PHP - 31.11% MySQL) with 11 queries |
