Old 23rd January 2012, 04:51 PM   #1
alibear is offline alibear  United Kingdom
Default Oriantation of smoothing/filter electrolitics.
Hi all, seems I'm always asking questions but here go'es.
Are there any views about mounting smoothing capacitors in power supplies, which is most favorable- mounting them vertical or horizontal.I'm talking about large value ( 47,000 micro farad ).
The reason I ask is I am trying to fit them in a confined space and fitting them horizontaly would be easier, but I think I read that they dry out if they are mounted that way. Any thoughts?
thanks
Alan
Old 23rd January 2012, 07:09 PM   #2
Vertical is best. That is because if they overheat and have to vent they will likely expel gases before electrolyte, which may give you time to shut everything off and minimize damage. If mounted horizontally, put the vent plug at the top for the same reason and try to lay out your system so that any expelled electrolyte is aimed away from the expen$ive parts. In the horizontal position expulsion of electrolyte is far more likely if the cap overheats.
Using high-temp caps, in-rush limiters, overheat and overcurrent safe guards (obviously) minimizes the likelihood of failure.
Cheap motor caps(MKP) vs Electrolitics rvrazvan Tubes / Valves 12 8th November 2011 05:36 PM
Smoothing caps cr0wl3y Tubes / Valves 2 12th January 2010 10:40 AM
Solid electrolitics vs audio grade electrolitc capacitors gto127 Solid State 29 27th October 2009 07:13 PM
Whats the diference between RB and RG electrolitics?? SkinnyBoy Everything Else 0 13th January 2003 04:33 AM
HV smoothing capacitors DeXXSter Tubes / Valves 8 11th December 2001 10:10 PM
Page generated in 0.07581 seconds (62.74% PHP - 37.26% MySQL) with 10 queries
