Hi
we are looking for the value of a blown resistor. It's the din plugged earlier version of the 8000a. The component is in the moving coil section. To describe where it is, there are some transistors 1,2,3,4 etc. immediately right of tr1 is a vertical resistor value 3k3 under this horizontally is the resistor that's burnt. the 1st colour looks like orange. If you know the value that's great, failing that could you send me a high res photo that we could zoom in and see the value ? many thanks in advance. |
#2 |
Can't you post a picture?
#3 |
Why are some people just so LAZY.
It took me 20 seconds to Google the schemtic. |
#4 |
Hi, the posted schematic is just the power amplifier stage, what is needed is the MC stage, rgds, sreten.
The easiest method is checking the same resistor in the other channel, unless the said resistor is part of a common power supply for both channels, then you would need the power supply schematics.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 20th January 2012 at 03:28 PM. |
#5 | |
took me less than that before I posted this thread !! . . but as kindly pointed out by sreten that's just the power stage. I need the mc stage. Sreten, I will take a look. It's at my friends at the moment. He's good with electronics! Puffin, I could post a picture, but it's at my friends at the moment and I don't think I can get there until next week and I know his camera isn't working! I was hoping someone might be able to sneak a look inside if they had one and follow the description. Failing that I will try and get a photo up as soon as possible thanks for the posts |
#6 |
Sorry. I did notice that my post only had the pa stage.
I run Arcam and find them ever so accomodating. Not too sure who owns Audiolab these days. Have both L + R failed.... |
#7 |
No, what it is, my friend who fixes and upgrades hifi got this a few years back and used it as an experiment to see just how far he could take the audiolab. It's been up in his loft ever since! I'm interested to hear how it compares to what I have. He has checked it out to make sure it's all ok and has found this resistor burnt out.
#8 |
Hi hopes this helps
regards jim |
#9 |
Jim, you are a gentleman !!!
I've emailed it to my friend. Hopefully it will help. many thanks and have a great weekend |
#10 |
Hello Jim. Do you happen to have the schematics for the pre-amp section of the Audiolab 8000a? Or the rest of the amplifier? Thanks!
| Audiolab 8000a | dantzig65 | Solid State | 9 | 6th June 2011 02:48 PM |
| Schematic for Audiolab 8000a | Edlo | Solid State | 30 | 25th March 2010 03:03 AM |
| Audiolab 8000a fuse | badnote | Solid State | 2 | 14th May 2009 01:57 PM |
| Help! Audiolab 8000A | Matthewong | Solid State | 9 | 15th October 2007 06:09 PM |
| audiolab 8000a | davephot | Solid State | 35 | 26th November 2006 10:25 PM |
| Page generated in 0.11132 seconds (73.86% PHP - 26.14% MySQL) with 11 queries |
