Old 18th January 2012, 05:19 PM   #1
maxpou is offline maxpou  Canada
maxpou's Avatar
Default Power amp suggestion
Hi Guys,
I would like to built a new power amp. I have many parts here, 2 xformer 35-0-35 Vac 2500VA, Bjt output 8 mjl1302 and 8 mjl3281 onsemi, driver toshiba 20 2sa1930 and 20 2sc5171, 10 2sa1381 and 10 2sc3503, 20 MJE15030 and 20 MJE15031, many 2n5401 and 2n5551, many BC546B and BC556B, many 2sa970BL and 2sc2240BL and many 2SK170BL and 2SJ74BL.
I want can put a Dunlavy SC-IV on this amp without problem. Somebody can suggest me? Thank you! Maxpou
Old 18th January 2012, 05:44 PM   #2
wahab is online now wahab  Algeria
With such a transformer , the poor devices on the left
can only hope that such a question will stay unanswered....
Old 18th January 2012, 05:47 PM   #3
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Well , maybe all for one channel .....
Old 18th January 2012, 06:02 PM   #4
maxpou's Avatar
Why?
Old 18th January 2012, 06:06 PM   #5
maxpou's Avatar
you believe I don't have enough parts to built 2 channel. Maxpou
Old 18th January 2012, 06:25 PM   #6
With a 35-0-35Vac transformer you can expect a sinewave output of ~29Vac.
This gives ~100W into 8r0 and gives ~200W into 4r0.
Two channels of 200W into 4r0 would require a transformer from 400VA to 800VA.
Your transformer is wasted on that.
regards Andrew T.
Old 18th January 2012, 06:50 PM   #7
indianajo's Avatar
With two transformers, you can stack them up end to end and make +-70 VAC. Of course, it would be incredibly heavy. Then your number of output transistors and heat sink size would limit your power. Better install good overcurrent (output) protection.
Cool Andrew says you can get 29 VAC out of 35 VAC rails. The amps I have been working on produce about 2/5 to 3/5 the rail voltage on the speaker output by specification. I thought modern transistors might be better.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500
Old 19th January 2012, 12:40 AM   #8
maxpou's Avatar
Hi guys!,
I don't know what wrong with my big transformer? I can't built a power amp with them? maxpou
Old 19th January 2012, 01:08 AM   #9
a.wayne's Avatar
Max you can and if you double the outputs it will be a monster at 2 ohm ...
Old 19th January 2012, 03:20 AM   #10
tinitus is offline tinitus  Europe
use monster classA rated heatsinks
diode rectifier suggestion for power supply necplusultra Power Supplies 1 25th January 2011 10:29 PM
Class A low power (5-10w) amp suggestion needed s3tup Solid State 42 13th April 2010 06:45 PM
Need suggestion about power supply config consideration goldkenn Chip Amps 6 11th June 2008 03:12 PM
Suggestion for Power AMP ! 150W @ Ohms -_nando-_ Solid State 11 1st October 2006 09:12 PM
Need Suggestion for Input Stage For Power Follower 99 Mark A. Gulbrandsen Tubes / Valves 6 11th November 2001 10:00 PM
Page generated in 0.10198 seconds (76.70% PHP - 23.30% MySQL) with 11 queries
