Old 18th January 2012, 01:37 AM   #1
Default Perreaux 2150B & SM2 issues
Greetings to all from Canada,
I have recently acquired a Perreaux 2150B amp and SM2 preamp to drive my fully restored Gale GS401 speakers and I’m seeking advice on three issues:
  1. Power switch: the amp will switch on but will not switch off normally. If I hold the switch depressed for several seconds the amp may power down when I release the switch. It can take several attempts to achieve this and if all fail I just pull the power cord out! Not a good idea.
  1. Preamp gain: the output of the preamp is so high that I can reach maximum tolerable levels by advancing the volume control only to 7:00 o’clock position, where 6:00 is zero. Is this normal for this preamp? [/FONT][/SIZE]
  1. The sound: I would characterize the sound of my system as clean, articulate, powerful and exhilarating for the first half hour. From that point on, however, it gradually becomes a joyless “music-in-your face” experience. Which is not only a great disappointment but entirely inconsistent with MOSFET design from a highly reputable source.
What can I do about the power switch? Do I need a different preamp? Can I tame the beast by changing interconnect and speaker cables or am I facing a major restoration project? And, if so, is it worth it? Your comments and suggestions would be very much appreciated.
Old 18th February 2012, 05:26 AM   #2
Monte Verdi's Avatar
These fine units were produced in the early to Mid 80"s so there powersupply caps, and Wima film caps are likely tired and exhausted, that has been my experience with Perreaux from this time period. The 2140B is a really fine amp when it is set up properly.
Problem with gain (preamp) could be Alps pot gone south, no good anymore.
On off switch (amp) likely needs replacing etc.
If your going to own an 80's Perreaux or any Class A Solid State from the 1980's you must be prepared to replace parts, and newer finer engineered parts today make these amps compete with some of the finest (IMO)! Solid State circuit design has not evolved that far from the the 1980's.
Old 18th February 2012, 07:24 AM   #3
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
read this about the switch, they are known to fail...
Perreaux_Amps
I think the sm2 was pre cd, it was designed for lower gain sorces. You may need to use a voltage divider to reduce the gain.
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Perreaux SM2 Custom Monte Verdi Analog Line Level 6 11th May 2012 01:02 PM
Recapping a Perreaux 1150B amp? NH7RO Parts 42 23rd June 2011 09:49 AM
Transformer issues? Perreaux 2150B Pix, Schematic... jmlandry Solid State 8 9th June 2010 10:12 AM
Perreaux SM2 & 2150B... nickds1 Solid State 40 20th July 2009 01:03 PM
Page generated in 0.07725 seconds (80.44% PHP - 19.56% MySQL) with 11 queries
