High bias and distortion in one channel of GFA 545 w schematic
Old 18th January 2012, 01:21 AM   #1
spice house is offline spice house  Luxembourg
Default High bias and distortion in one channel of GFA 545 w schematic
Hello I bought a used GFA 545
One channel is totally fine,
I've measured a 150mv bias current across TP1 and TP2 in the faulty channel (should be 6.5) There is audible distortion on that same channel There is no extra noise when no music is playing
Can someone help me troubleshoot this problem? Thank you
ImageShack® - Online Photo and Video Hosting
Old 18th January 2012, 01:40 PM   #2
I should also add both channels have an offset of about 35 to 40mv
Old 18th January 2012, 02:06 PM   #3
east electronics is offline east electronics  Greece
east electronics's Avatar
driver Q621 leaky
thermistor 601-problem
Q 617 - 619 leaky
C607 leaky
VR 601 open or other
Could also be a combination of the above
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 18th January 2012, 02:30 PM   #4
Originally Posted by sakis View Post
driver Q621 leaky
Q 617 - 619 leaky
C607 leaky
Thank you! R645 (Q625 E pin) is reading 150mv, thats where the bias is coming from, no other output emitter resistors have that voltage does that narrow it down? It's receiving proper voltage, so that means its q625 gone bad?
Old 18th January 2012, 03:10 PM   #5
I desoldered Q625, reseated, and soldered it back in, cleaned it and it magically works again
Old 18th January 2012, 04:37 PM   #6
carlmart is offline carlmart  Brazil
Well, I was going to add cold solder to sakis list, and apparently that might have the case on Q625.
If possible I'd check and/or re-heat all solders on the amp, or at least on the faulty channel. It might have been an assembly problem.
High bias and distortion in one channel of GFA 545 w schematicHide this!Advertise here!
Adcom GFA-545 II Schematic Needed 1moreamp Solid State 4 18th September 2012 03:11 AM
Fan issue Adcom GFA-5800 bias too high? ben62670 Solid State 3 26th April 2012 06:23 PM
ic for GFA 545 east electronics Solid State 1 14th March 2011 06:39 PM
Adcom GFA-545 adventfan Solid State 3 4th February 2011 03:08 PM
Adcom Schematic Needed Gfa-545 Ii Mattyo5 Solid State 8 12th June 2003 03:56 PM
