Hi
Anyone have a paper discussing the various methods of protecting opamp inputs?? I know there are a couple of ways, but uncertain as to which works best where. |
#2 |
To protect against DC, coupling cap. What other kind of protection would you wish?
If my 15 V DC were the radius of the Earth, Mount Everest would be 1 meter tall. |
#3 | |
The ways simply to protect it is: 1. Connect input opam with resistor to current limit input.This way is not very good results but may be acceptable. 2. Use two diodes connected reverse with B+/B-.This way is very good results but diode may be cause noise,rarely used in hi-end circuit. What do you ways to protect opamp? Regrads,
Ultraline1@gmail.com Last edited by hien.t.nguyen; 16th January 2012 at 04:34 PM. |
#4 |
#5 |
Thanx Discrete!!!
That will do just fine. |
| How do the protection diodes on an opamp's input exactly work? | ribolovec2 | Everything Else | 6 | 21st November 2011 05:38 PM |
| Input protection diodes: More harm than good? | MJL21193 | Solid State | 16 | 20th November 2008 02:49 AM |
| Input Protection | Devil_H@ck | Chip Amps | 5 | 21st January 2007 04:49 PM |
| Protection of Mosfet Amps from input Overdrive... | Workhorse | Solid State | 21 | 22nd June 2005 03:57 PM |
| Opamp as tube driver: Protection ideas? | Franz G | Tubes / Valves | 5 | 17th August 2004 08:10 AM |
| Page generated in 0.07705 seconds (73.78% PHP - 26.22% MySQL) with 10 queries |
