Class A heatsink question - Page 2 - diyAudio
Old 17th January 2012, 08:31 PM   #11
djk is offline djk
djk's Avatar
TO-3 with grease is about 0.9°C/W in my book.
BeO2 is about 0.17°C/W.
Candidates for the Darwin Award should not read this author.
Old 17th January 2012, 09:51 PM   #12
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
The mica adds 0.3C/W, does not imply that Rth c-s is the same number.
(polished heatsink, polished TO-3 surface, best mica grade. mica rates from thin to thick, from best to worst origin)
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 17th January 2012, 11:00 PM   #13
djk is offline djk
djk's Avatar
0.09°C/W, moved the decimal one place.
Old 18th January 2012, 04:11 PM   #14
alibear is offline alibear  United Kingdom
alibear's Avatar
many thanks for all the assistance, much appreciated.
Andrew T, yes the 120mm fan will be fitted at the bottom of the heatsink.
Slightly off subject, using K Amps Class A Calculator I get the following results:
23V rails
3Pairs output devices
0.5 Ohm emmiter resistors
1.6Amp bias per rail
= 41W RMS and 74watts per channel heat dissapation.
Does this sound correct?
thanks
Alan
Old 18th January 2012, 04:18 PM   #15
KatieandDad's Avatar
You'll be very surprised as to how little air stirring you actually need in order to improve the heatsink transfer function of the heatsinks.
In my Pass Aleph 4 I'm ditching over 400W of heat into 8 heatsinks. Using two 50mm fans running at half voltage (ie the 2 x 12V fans in series across 12V). I've reduced the heatsink temperature by nearly 10 degrees and the fan noise is almost inaudible.
Heatsink candidate for Class D amps CanAm Man Chip Amps 1 19th September 2011 10:36 PM
Heatsink candidate for Class A? CanAm Man Pass Labs 9 17th September 2011 06:24 PM
ab class heatsink dimensioning morpheus82 Solid State 6 21st April 2005 09:35 PM
heatsink question? xdissent Solid State 13 18th June 2004 02:44 AM
N.E.W A-60 Class A heatsink vsr123 Pass Labs 10 19th May 2004 07:45 PM
Copyright ©1999-2017 diyAudio
