e-Amp e-Amp - diyAudio
e-Amp
e-Amp
Old 15th January 2012, 11:31 AM   #1
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Default e-Amp
My new power amp ('e-Amp') is coming along quite well. The main boards power amp boards have been assembled and the protection and in-rush board has had the s/ware written and debugged. Still a lot of work to do, but it will probably be up and running in about 3 weeks. I'll post circuits, more pictures and a full write-up once testing is complete. There is a very small write up on my website below in the interim.
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Old 15th January 2012, 11:58 AM   #2
Bonsai's Avatar
BTW, compensation is selectable using jumpers for either standard MC, TMC, or a hybrid comp scheme I've called WB-TMC.
bonsai
Old 15th January 2012, 12:11 PM   #3
wahab is offline wahab  Algeria
Looks neat....
Apparently , a symetrical differential design.....That s great if true.
Those are very rare.
Old 15th January 2012, 12:13 PM   #4
Bonsai's Avatar
Thanks Wahab!
Yes, symmetrical differential design and EF3 - my preferred topology!
bonsai
Old 15th January 2012, 05:20 PM   #5
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
We do share some layout ideas Bonzai, this is ELD prototyped Oct 2010. Also dual symmetrical and uses 2SK1058/2SJ162 driving 3 pairs of MJL3821A/1302A.
Front end runs off a voltage doubler and shunt regulated to 70V while the main amp runs from 48V.
Kindest regards
Nico
Old 16th January 2012, 04:28 AM   #6
Bonsai's Avatar
Very nice Nico - yes, I like this layout as well - great for spreading the heat and clamping the devices to the h/sink.
This e-Amp is running off +-73V (actually a bit on th high side, but it can live with it) and I am using a ripple eater on the pos and neg supplies to the front end.
I have a 50 odd page write -up I'll stick up on my site once the nit is assembled and tested - still need a few more weeks though.
bonsai
Old 11th May 2012, 07:23 AM   #7
Walkalone is offline Walkalone  Viet Nam
@Bonsai: Look very good! I'm very interested.
Can you show the schematic and spec? (THD, Slew rate, BW... ect...?)
Old 11th May 2012, 08:14 AM   #8
Tekko is offline Tekko
Banned
That look just too professional to be homemade!!
You sure u arent rebuilding a commercial amp ?
Old 11th May 2012, 11:10 AM   #9
Bonsai's Avatar
Ha ha. Lol
No, the boards are made by a PCB house, but everything else is home made. I even file th holes in h chassis. This week end maybe it is wired up completely!
bonsai
Old 11th May 2012, 11:12 AM   #10
Bonsai's Avatar
Walk lone, yes, when I have finished the listening tests in. Few weeks I will publish something.
bonsai
e-AmpHide this!Advertise here!
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 03:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 09:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 10:28 AM
Copyright ©1999-2017 diyAudio
