Old 13th January 2012, 10:27 AM   #1
Default Marantz PM-40SE No sound.
I am going crazy. Received this amplifier as broken. There were plenty of bad joints but after resoldering it does not give a sound. It turns on, LEDs are on but no “click”.
I checked drivers, I tried run it without drivers – no effect. The PSU voltage seems to be ok: +/- 38.4V (for drivers) OK, +24V OK, -18V OK. I do not have 2.9V on pin 9 and 1.3V on pin 8 of TA7317P (protect circuit).
Any ideas?
Old 13th January 2012, 10:37 AM   #2
Audiofanatic's Avatar
Default schematic
Hi
Do you have a schematic of the amp and a scoop and signal gen.
Audiofanatic
Be nice to animals.
Old 13th January 2012, 10:45 AM   #3
Mooly's Avatar
Originally Posted by Audiofanatic View Post
Hi
Audiofanatic
+1
We need to see the circuit.
Have you checked the DC offset voltage at the output (before relay) of each channels power amp. What does it measure ?
Is the output stage drawing current (check by measuring across emitter resistors). What is the current ?
A simulation free zone. Design it, build it, test it.
Old 13th January 2012, 11:18 AM   #4
Thanks guys,
Diagram herehttps://dl-web.dropbox.com/get/maran...pdf?w=bc6e9674
I did not check offset before relay. I'll measure it and post .
Old 13th January 2012, 03:47 PM   #5
Mooly's Avatar
The dropbox thing say I don't belong
If the pdf is under 1mb try putting it in a zipped folder and posting directly on the site.
Offset is the first thing to check (with the drivers fitted).
Old 13th January 2012, 04:09 PM   #6
Ok.
The schematic is here
Old 13th January 2012, 04:29 PM   #7
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Resistors 801, 802, 803, 804 in the PSU blow in the PM-66 and cause similar symptoms
Try checking them.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 13th January 2012, 05:38 PM   #8
Default Check the resistors
Like mooly said check for DC offset on the output before the relay.
This can be done by measuring the voltage on the resistors R713 and R714. measure both sides of those R's.
The offset must be around 0 volts. If it's more than the protection circuit will never release the relay.
Audiofanatic
Be nice to animals.
Last edited by Audiofanatic; 13th January 2012 at 05:39 PM. Reason: wrote the name of my fellow member wrong.
Old 13th January 2012, 09:04 PM   #9
+1
There is 6mV on both after power up.
Try checking them.
Andy
Resistors 801, 802, 803, 804 are checked. I have +24.3V and -17.3V on emiter Q801 and Q802
Audiofanatic
Right. It is not around ZERO. It is -14.5V !!!
Old 14th January 2012, 10:56 AM   #10
Mooly's Avatar
You need to recheck your readings... look at the circuit
The 6mv (where I said to measure before the relay) are the same points (apart from passing through the large output inductors as R713 and 714. Something amiss in the readings there (unless something drastic has happend like it being dropped and the PCB is cracked).
Measure the DC voltage on the "output" line. That is the line that goes to L751 and L752. It should be around zero. If R713/4 really are at -14.5 then there is physical damage as it is a direct connection between these points.
Marantz PM 440 and PM 351 Schematic required Krokotam_ Solid State 0 22nd October 2008 07:36 AM
Marantz PM-11S1 Ipanema Solid State 2 31st July 2008 02:37 PM
Marantz PM 94 Help brams Solid State 6 27th February 2006 06:23 AM
Marantz PM 55 elec972 Solid State 0 6th December 2005 11:57 PM
Marantz Pm-66SE geddam Solid State 2 28th April 2005 02:15 AM
Page generated in 0.12565 seconds (74.65% PHP - 25.35% MySQL) with 11 queries
